Originally Posted by SirTanon
Well, keep in mind that the best use of a UOA (multiple, really) is to track trends. The best way to do this is to get a baseline reading early on and then do them every so often and if something changes noticeably from one UOA to another, then it can potentially signal a problem.
If you wait until the car is 5 years old, how will you know what the numbers looked like when it was new?
With our new 2017 2.3 EB Explorer I wanted to establish realistic OCI. And not just rely on the iOLM, which is based upon a 5W-30 oil meeting the easily met Ford specification. A conventional oil can even meet the Ford 5W-30 spec. Do you want to run a conventional oil for 10,000 miles in a DI Turbo engine? Because that's what my iOLM always went for. I changed the ff at 2,000 mi and used the dealer conventional oil change for another 3,200 miles. Then I ran 7,000 mi of mainly high speed summer driving with Mobil 1 5W-30 and did an UOA. Next I did a late August to early December OCI, 4,275 mi, with Motorcraft 5W-30 and an UOA. Thirdly I did a winter to spring OCI of 6,200 miles with Mobil1 5W-30 and an UOA. This one had of course many freezing days and remote starts. The summer run of Mobil 1 was still in grade with low wear metals showing. The low mileage Motorcraft oil OCI run had sheared substantially out of grade for 4,275 mi, of easy driving, but again with low wear metals. The winter run of Mobil 1 sheared just out of grade but it was subject to extreme winter conditions, ie lots of remote starts and extremely cold temps. Again it had low wear metals. From my UOA's and using Mobil 1 5W-30 I know I can increase the OCI comfortably if the weather allows. I can only change the oil outdoors, so winter oil changes bite needless to say. For me my UOA's were good to establish a reasonable OCI with Mobil 1 5W-30, which I plan to use.
Whimsey
