Forscan for Windows
by Donald - 01/24/20 07:30 AM
Group IV/V confirmed gear oils?
by metroplex - 01/24/20 06:34 AM
SATA Tools
by demarpaint - 01/24/20 05:10 AM
C-130
by Exhaustgases - 01/24/20 01:29 AM
Anyone Here Have a 9-Shot Rough Rider?
by ZeeOSix - 01/24/20 12:43 AM
Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
84 registered members (AZjeff, Bettez88, aba4430, 53' Stude, Bailes1992, 10 invisible), 2,756 guests, and 18 spiders.
Topics300,484
Posts5,176,947
Members70,514
Engine friction reduction trends #4830433 08/03/18 05:05 PM
J
JAG Offline OP
J
The main points should be familiar to those of us who read oil papers, but Iím posting it because itís a good paper. Itís from 2016.
The statements below are not all in the paper. Some come from other sources.
Thinner oils push the lubricant regimes to the left on the Stribeck curve. Yep, itís still true...darn physics.
Friction modifiers help reduce mechanical friction when asperity contact occurs. Fuel economy benefits of thin oils are especially realized (compared to thicker oils) when friction modifiers are added because of the increased asperity contact caused by thin oils.
Near the top and bottom dead center piston positions are the problematic regions due to the low relative speeds there causing oil film thickness collapse. The piston rocking back and forth there makes it even worse for the film separating the piston skirts from cylinder walls. There, the shear rates are very low, so low-shear rate kinematic viscosity is the driver rather than the high shear rate like is used in the HTHS test.
The paper: https://link.springer.com/content/pdf/10.1007%2Fs40544-016-0107-9.pdf
Re: Engine friction reduction trends [Re: JAG] #4830466 08/03/18 06:10 PM
Marco620 Offline
Interesting... Very interesting. So.. Keep using redline 0w20 in my car, right??
15' Civic 1.8 i-vtec 302,000 mi M1 AP 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,Heckler & Koch & SONY Aficionado
Re: Engine friction reduction trends [Re: JAG] #4830506 08/03/18 06:58 PM
J
JLTD Online Shocked
Online Shocked
J
popcorn
(and also don't have time for the whole article right now)
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, 35k, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Engine friction reduction trends [Re: Marco620] #4830515 08/03/18 07:03 PM
B
bulwnkl Offline
B
Maybe, maybe not...
If this is an overriding or controlling issue:
then you'd want a fluid with a higher kinematic viscosity, but not really a higher dynamic (HTHS) viscosity. Or, in other words, kind of the opposite of what you get from Redline's fluids: A reasonably '[censored]' 10W30 rather than a Redline-type 0W20.
...but that's only _if_ that one quoted principle is overriding or controlling in terms of overall wear that leads to engine failure or replacement.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Engine friction reduction trends [Re: JAG] #4830599 08/03/18 08:34 PM
O
Onetor Offline
O
What a paper to digest. I think I need to read it twice. I'm a newbie,,,,
N = R* x fp x ne x fl x fi x fc x L
Re: Engine friction reduction trends [Re: Onetor] #4830623 08/03/18 09:15 PM
CR94 Offline
Yeah. They throw in a little of everything---plus more than a few typos. Yes, I made it all the way through.
2011 Toyota Prius now at 108K
Re: Engine friction reduction trends [Re: JAG] #4837695 08/11/18 09:18 PM
Z
ZeeOSix Offline
Z
These graphs were posted in another thread awhile ago - don't recall which thread or by who. Shows that ring wear is a function of oil temp, oil HTHS rating and engine RPM. Still shows that higher HTSH will reduce ring wear in certain operating conditions. Also, it's pretty typical that higher viscosity oils will also have higher HTHS ratings.
Another reason to use thicker oil IMO is to reduce ring wear based on these graphs ... especially if you're pushing the engine hard (load and RPM), and elevating the oil temperatures above what you'd see in normal street driving.
Re: Engine friction reduction trends [Re: ZeeOSix] #4888783 10/05/18 10:28 PM
N
neo3 Offline
N
[Linked Image]
[Linked Image]
I'm not seeing the same conclusion from those graphs, especially the 2nd one that seems to show that an HTHS of 2.6 has the minimum average wear over the entire rpm range. That HTHS would be typical for a "thinner" oil (XW20) wouldn't it? (Also, they really need another data point in there around 2.9.) Maybe I should change my preference for using "thicker" oil (picked up from reading too much stuff on this site LOL). It would be useful to have a link or citation for the graphs.
Re: Engine friction reduction trends [Re: JAG] #4891367 10/08/18 06:50 PM
CR94 Offline
^^ Agree with neo3. There are also odd inconsistencies in speed vs. wear in those plots. What is "h·piece" in the vertical axis? (I assume something related to run time or number of revolutions.)
Re: Engine friction reduction trends [Re: neo3] #4891462 10/08/18 08:36 PM
Z
ZeeOSix Offline
Z
The 2nd graph is showing that increased wear can occur for oils that are less than 2.6 HTHS when oil temperature gets elevated some. But it also says if you are using a 20 wt you really have no headroom, but are right at the verge of having more engine wear is the oil temps start to rise above "normal". Look how the wear rates all increase when you go a hair below 2.6. Personally, I don't want to always be operating on the edge of the wear cliff when pushing the engine hard. HTHS of 2.6 is probably fine for tootling around like grandma on the streets. grin2 Notice the wear is basically flat lined for the 2000 RPM case, regardless of the HTHS.
Re: Engine friction reduction trends [Re: JAG] #4891777 10/09/18 09:37 AM
B
bulwnkl Offline
B
Yes, those generalities do seem to be in there, but there also appears to be a very large amount of variation (scatter, really) such that those graphs are not adequate to give me a visual representation I can have confidence in.
Re: Engine friction reduction trends [Re: JAG] #4891993 10/09/18 02:16 PM
CR94 Offline
^^ Yes. It's interesting that 2.6 mPa·s appears to protect better than 3.1 at most speeds---unless that's merely an artifact of the scatter.
