Zoro.com 20% off sale
by SubieRubyRoo. 06/18/19 06:24 AM
Why such a low temp thermostat?
by Chris142. 06/17/19 11:21 PM
Abnormal Wear on Tire?
by A_User55555. 06/17/19 11:17 PM
Jag F Type
by Snagglefoot. 06/17/19 11:00 PM
Autozone $7 Coupon
by TheLawnRanger. 06/17/19 10:00 PM
5W20 Pennzoil Platinum vs. Pennzoil Ultra Platinum
by DrivinWest. 06/17/19 09:30 PM
Taillights cloudy (never)?
by WhizkidTN. 06/17/19 09:26 PM
2017 Silverado Front Bumper & Skid Plate??
by Mr_Joe. 06/17/19 09:20 PM
AC Issues - 2007 Chrysler Pacifica
by 92saturnsl2. 06/17/19 08:33 PM
Harbor Freight 4x8 Trailer $250
by FordBroncoVWJeta. 06/17/19 07:57 PM
Iron Butt Rally 2019
by Jarlaxle. 06/17/19 07:13 PM
Champion oil filters $1.34 at Rock Auto
by wemay. 06/17/19 07:12 PM
Stumped on which tire direction to go
by Pat in Speedway. 06/17/19 06:44 PM
Dealer Invoice, Hold Back, and Factory Incentives
by LoneRanger. 06/17/19 05:46 PM
HF Recall on 14" Electric Chainsaw
by SubLGT. 06/17/19 05:34 PM
Does the GM G80 need LS fluid?
by K20FA5. 06/17/19 05:07 PM
Pink Seats LS430
by Gebo. 06/17/19 04:58 PM
PublicStellar, vacant, TallTravel, MrTire, Skraeling
68422 Registered Users
63 registered members (Anthony, bbhero, 2015_PSD, berniedd, 77GrandPrix, 7 invisible), 996 guests, and 18 spiders.
Topics290,603
Posts4,989,303
Members68,422
Most Online2,967
Mar 10th, 2019
2019 Honda CB300R Factory Fill #4884912
10/01/18 07:48 PM
10/01/18 07:48 PM
Idaho Falls, ID
Jay Offline OP
Jay  Offline OP
Idaho Falls, ID
Lab: Western States Caterpillar
Date: 19 Sept. 2018
Miles on Oil: 760
Miles on Bike: 760
Cu 10
Fe 22
Cr 1
Al 20
Pb 0
Sn 0
Si 32
Na 9
K 5
Mo 2
Ni 2
Ag 0
Ti 0
V 1
Mn 4
Cd 0
Ca 1952
P 1003
Zn 972
Mg 17
Ba 59
B 171
V @100C 8.2
ST 0
Oxi 8
Sul 19
Nit 6
W N
A N
This is factory fill which was presumably 10W-30 Honda GN4 oil which is Honda's recommended oil for this engine. Honda recommends changing the oil/filter initially at 600 miles. Thereafter, 8kmi intervals. The only thing noteworthy that I spot is that it has sheared out of grade.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885105
10/01/18 11:42 PM
10/01/18 11:42 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
The additive numbers make me think it's basically a newer oil with slightly elevated ZDDP and detergents.. nothing special. Your wear numbers look about average for most factory fill analyses.
As for the grade -- I'm starting to think that the engineers spec a thicker weight on purpose with the knowledge that it'll shear down by the time you change the oil. Seems like Honda has no concerns about engineering their bikes around thinner oils.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885357
10/02/18 10:43 AM
10/02/18 10:43 AM
Arizona
bulwnkl Offline
bulwnkl  Offline
Arizona
Honda’s GN4 oil is reasonably low quality is all. ;-)
OP, I expect that your CBR will run well and last a long time. I don’t personally care for Honda GN4 oil, at least for the price they want, but lots of bikes run on it and seem to be okay.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4886313
10/03/18 10:15 AM
10/03/18 10:15 AM
Idaho Falls, ID
Jay Offline OP
Jay  Offline OP
Idaho Falls, ID
Honda is fairly generous in its oil recommendations. They say pretty much any SN oil will do as long as it's 10w-30 and non energy-conserving or resource-conserving. I'm using Chevron Delo 400 10w-30 XLE in it now. This is a multi-fleet oil that meets SN and a number of diesel designations also. I noticed a distinct improvement in shifting after the switch.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4887094
10/04/18 10:31 AM
10/04/18 10:31 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
vanadium ??? really?
barium?
that much manganese?
ummmmm, where is the unobtanium?
and a CsT of 8.2 is....well close to water its 20wt
motorcycle oil myth buster
Re: 2019 Honda CB300R Factory Fill [Re: bulwnkl] #4887332
10/04/18 02:22 PM
10/04/18 02:22 PM
FL
eddy21 Offline
eddy21  Offline
FL
They didn't test well years ago .
15 Fiesta ST
Re: 2019 Honda CB300R Factory Fill [Re: sunruh] #4887352
10/04/18 02:38 PM
10/04/18 02:38 PM
Central Texas
Brian553 Offline
Brian553  Offline
Central Texas
barium?
Has anything that shows up less than 10 every been significant enough to confidently say it's real foreign substance in the crankcase? (apart from silicon)
I always assumed it was just noise
Re: 2019 Honda CB300R Factory Fill [Re: Brian553] #4887975
10/05/18 08:18 AM
10/05/18 08:18 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
barium?
in my own personal testing, the 1st time that Ti showed up, i pulled the head to find the Ti valves tuliping. the value was 2
now, usually, yes its just scatter noise. which means its not been calibrated very well. or is just a poor unit to begin with.
which means only 1 thing: are your test results worth a darn?
so does the value mean anything? it all depends on if you want to believe your results.
if you do believe them, then you need to investigate it.
if you do not believe them, why do the test?
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4890147
10/07/18 03:10 PM
10/07/18 03:10 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Interesting to see ZN/P levels inverse of what you normally would find. Who knows what other phosphorous additive might be used?
95 Cherokee 190K DELO 10W30, XG8
07 IS250 110K Frankenbrew, WIX 57173
04 YZF-R1 19K DELO 15w40, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 503 FF, Mopar
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4896719
10/15/18 03:31 AM
10/15/18 03:31 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Sheared out of grade in 760 miles ... Wow. Wonder if it was some special factory oil and not actually a 10W-30.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4897426
10/15/18 09:20 PM
10/15/18 09:20 PM
Arizona
bulwnkl Offline
bulwnkl  Offline
Arizona
Not likely. Honda's GN-4 oil is not a particularly shear-stable fluid. IMO it's not really a particularly good quality fluid at all.
