Hey,
I have a Focus SVT with bent valves due to a defective brand new OEM timing belt tensioner when doing a timing belt change. This particular engine is the interference version of the ZTEC. The failure happened at idle and I still bent about 12 valves.
It is super hard to find a used head and all I have are some used, known good valves that I removed from another head. The community and support for these engines is very slow moving.
Could I lap the valves and stick them in the head? Does it need to go to a machine shop? My local machine shop is very pricey and run by an idiot. The valves are like $35 each. I checked the head for warp and there is very little...falls nicely within Ford's spec.
Thanks.
Thanks.
