engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
Castrol Edge 5w20 and 5w30 Costco
by nlife - 02/16/20 02:41 PM
Generator Hour Meter
by spasm3 - 02/16/20 01:44 PM
VW Budack Cycle 2.0T - hugely unimpressed.
by pezzy669 - 02/16/20 01:13 PM
Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Clifton, JohnEmm, Fastvette, Geode, rob1715
70716 Registered Users
111 registered members (2013ecof150, Alfred_B, 94astro, 762fermeandyou, 2009Caraman, 13 invisible), 2,508 guests, and 36 spiders.
Topics301,526
Posts5,197,288
Members70,716
2019 Honda CB300R Factory Fill #4884912 10/01/18 06:48 PM
J
Jay Offline OP
J
Lab: Western States Caterpillar
Date: 19 Sept. 2018
Miles on Oil: 760
Miles on Bike: 760
Cu 10
Fe 22
Cr 1
Al 20
Pb 0
Sn 0
Si 32
Na 9
K 5
Mo 2
Ni 2
Ag 0
Ti 0
V 1
Mn 4
Cd 0
Ca 1952
P 1003
Zn 972
Mg 17
Ba 59
B 171
V @100C 8.2
ST 0
Oxi 8
Sul 19
Nit 6
W N
A N
This is factory fill which was presumably 10W-30 Honda GN4 oil which is Honda's recommended oil for this engine. Honda recommends changing the oil/filter initially at 600 miles. Thereafter, 8kmi intervals. The only thing noteworthy that I spot is that it has sheared out of grade.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885105 10/01/18 10:42 PM
R
Reddy45 Offline
R
The additive numbers make me think it's basically a newer oil with slightly elevated ZDDP and detergents.. nothing special. Your wear numbers look about average for most factory fill analyses.
As for the grade -- I'm starting to think that the engineers spec a thicker weight on purpose with the knowledge that it'll shear down by the time you change the oil. Seems like Honda has no concerns about engineering their bikes around thinner oils.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885357 10/02/18 09:43 AM
B
bulwnkl Offline
B
Honda’s GN4 oil is reasonably low quality is all. ;-)
OP, I expect that your CBR will run well and last a long time. I don’t personally care for Honda GN4 oil, at least for the price they want, but lots of bikes run on it and seem to be okay.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4886313 10/03/18 09:15 AM
J
Jay Offline OP
J
Honda is fairly generous in its oil recommendations. They say pretty much any SN oil will do as long as it's 10w-30 and non energy-conserving or resource-conserving. I'm using Chevron Delo 400 10w-30 XLE in it now. This is a multi-fleet oil that meets SN and a number of diesel designations also. I noticed a distinct improvement in shifting after the switch.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4887094 10/04/18 09:31 AM
sunruh Offline
vanadium ??? really?
barium?
that much manganese?
ummmmm, where is the unobtanium?
and a CsT of 8.2 is....well close to water its 20wt
motorcycle oil myth buster
Re: 2019 Honda CB300R Factory Fill [Re: bulwnkl] #4887332 10/04/18 01:22 PM
E
eddy21 Offline
E
They didn't test well years ago .
15 Fiesta ST
Re: 2019 Honda CB300R Factory Fill [Re: sunruh] #4887352 10/04/18 01:38 PM
Brian553 Offline
barium?
Has anything that shows up less than 10 every been significant enough to confidently say it's real foreign substance in the crankcase? (apart from silicon)
I always assumed it was just noise
Re: 2019 Honda CB300R Factory Fill [Re: Brian553] #4887975 10/05/18 07:18 AM
sunruh Offline
barium?
in my own personal testing, the 1st time that Ti showed up, i pulled the head to find the Ti valves tuliping. the value was 2
now, usually, yes its just scatter noise. which means its not been calibrated very well. or is just a poor unit to begin with.
which means only 1 thing: are your test results worth a darn?
so does the value mean anything? it all depends on if you want to believe your results.
if you do believe them, then you need to investigate it.
if you do not believe them, why do the test?
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4890147 10/07/18 02:10 PM
Dyusik Offline
Interesting to see ZN/P levels inverse of what you normally would find. Who knows what other phosphorous additive might be used?
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k M1 AFE 0w20, WIX 57047
18 RAM 3500 10k Delvac 15w40, DBL7349
96 Cherokee
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4896719 10/15/18 02:31 AM
Z
ZeeOSix Offline
Z
Sheared out of grade in 760 miles ... Wow. Wonder if it was some special factory oil and not actually a 10W-30.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4897426 10/15/18 08:20 PM
B
bulwnkl Offline
B
Not likely. Honda's GN-4 oil is not a particularly shear-stable fluid. IMO it's not really a particularly good quality fluid at all.
