rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Don't Try This at Home
by MrMoody - 02/22/20 12:11 PM
o_s, naterbomb, Jimiii, jb5150, ZProfessor
70783 Registered Users
118 registered members (2009Edge, 2009Caraman, 4WD, 55hambone, ABomb369, 13 invisible), 2,033 guests, and 20 spiders.
Topics301,802
Posts5,203,026
Members70,783
2019 Honda CB300R Factory Fill #4884912 10/01/18 06:48 PM
J
Jay Offline OP
J
Lab: Western States Caterpillar
Date: 19 Sept. 2018
Miles on Oil: 760
Miles on Bike: 760
Cu 10
Fe 22
Cr 1
Al 20
Pb 0
Sn 0
Si 32
Na 9
K 5
Mo 2
Ni 2
Ag 0
Ti 0
V 1
Mn 4
Cd 0
Ca 1952
P 1003
Zn 972
Mg 17
Ba 59
B 171
V @100C 8.2
ST 0
Oxi 8
Sul 19
Nit 6
W N
A N
This is factory fill which was presumably 10W-30 Honda GN4 oil which is Honda's recommended oil for this engine. Honda recommends changing the oil/filter initially at 600 miles. Thereafter, 8kmi intervals. The only thing noteworthy that I spot is that it has sheared out of grade.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885105 10/01/18 10:42 PM
R
Reddy45 Offline
R
The additive numbers make me think it's basically a newer oil with slightly elevated ZDDP and detergents.. nothing special. Your wear numbers look about average for most factory fill analyses.
As for the grade -- I'm starting to think that the engineers spec a thicker weight on purpose with the knowledge that it'll shear down by the time you change the oil. Seems like Honda has no concerns about engineering their bikes around thinner oils.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885357 10/02/18 09:43 AM
B
bulwnkl Offline
B
Honda’s GN4 oil is reasonably low quality is all. ;-)
OP, I expect that your CBR will run well and last a long time. I don’t personally care for Honda GN4 oil, at least for the price they want, but lots of bikes run on it and seem to be okay.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4886313 10/03/18 09:15 AM
J
Jay Offline OP
J
Honda is fairly generous in its oil recommendations. They say pretty much any SN oil will do as long as it's 10w-30 and non energy-conserving or resource-conserving. I'm using Chevron Delo 400 10w-30 XLE in it now. This is a multi-fleet oil that meets SN and a number of diesel designations also. I noticed a distinct improvement in shifting after the switch.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4887094 10/04/18 09:31 AM
sunruh Offline
vanadium ??? really?
barium?
that much manganese?
ummmmm, where is the unobtanium?
and a CsT of 8.2 is....well close to water its 20wt
motorcycle oil myth buster
Re: 2019 Honda CB300R Factory Fill [Re: bulwnkl] #4887332 10/04/18 01:22 PM
E
eddy21 Offline
E
They didn't test well years ago .
15 Fiesta ST
Re: 2019 Honda CB300R Factory Fill [Re: sunruh] #4887352 10/04/18 01:38 PM
Brian553 Offline
barium?
Has anything that shows up less than 10 every been significant enough to confidently say it's real foreign substance in the crankcase? (apart from silicon)
I always assumed it was just noise
Re: 2019 Honda CB300R Factory Fill [Re: Brian553] #4887975 10/05/18 07:18 AM
sunruh Offline
barium?
in my own personal testing, the 1st time that Ti showed up, i pulled the head to find the Ti valves tuliping. the value was 2
now, usually, yes its just scatter noise. which means its not been calibrated very well. or is just a poor unit to begin with.
which means only 1 thing: are your test results worth a darn?
so does the value mean anything? it all depends on if you want to believe your results.
if you do believe them, then you need to investigate it.
if you do not believe them, why do the test?
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4890147 10/07/18 02:10 PM
Dyusik Offline
Interesting to see ZN/P levels inverse of what you normally would find. Who knows what other phosphorous additive might be used?
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k M1 AFE 0w20, WIX 57047
18 RAM 3500 10k Delvac 15w40, DBL7349
96 Cherokee
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4896719 10/15/18 02:31 AM
Z
ZeeOSix Offline
Z
Sheared out of grade in 760 miles ... Wow. Wonder if it was some special factory oil and not actually a 10W-30.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4897426 10/15/18 08:20 PM
B
bulwnkl Offline
B
Not likely. Honda's GN-4 oil is not a particularly shear-stable fluid. IMO it's not really a particularly good quality fluid at all.
