Originally Posted by bubbatime
Never break the seal. Your engine is worth $5000 to $10,000, and its life rest on your oil filter seal being sufficient. You compress the gasket and use it one time. If you go through the trouble of removing the filter, than you replace it with a new oil filter.
Draining a few ounces of oil out of it is a worthless endeavor. I use filters for 15K miles which can be 3 oil changes. I leave them on, and its perfectly fine. The only measurable difference is that the new oil has a TBN of 8.99 instead of 9.00 had I changed the filter. Big deal.
This is very well said. That little seal is a life/death matter for an engine. I lost a $12,000 Ecoboost in our Transit van when an oil change shop put a new filter on top of the gasket from the previous filter, which had separated and stuck to the filter mount, which burst into a huge leak under high pressure. Bye bye oil and hello blown engine. Fortunately, the oil change shop took responsibility and their insurance covered a Ford factory reman engine. Yes, the remanufactured engine was $12 large, installed. It did come with a better warranty than a brand new one, which I thought was interesting. (3 years unlimited miles vs. 3 years 50 or 60 thousand.)
You just made me think enough about this that I'm going with a full three OCI's on the Jeep JK.
