The material is not like a solid rubber material that was stamped out of a sheet. It's kind of more like a composite fibrous material that is pretty sturdy and upon disassembly will probably be less like to tear apart as much as the paper and cork gaskets I had experience with that you scrap away forever to remove.
The U660e transmission was an odd ball because a lot of retailers show both the metal 3 fastener metal style strainer and the plastic body 2 fastener style being compatible. I went with the plastic body style and crossing my fingers that this is correct one from what I read as the latest revision for the newer models for this 6spd generation.
