Hybrid HDD?
by demarpaint. 02/21/19 10:43 AM
Fat Wallet Forum
by LazyDog. 02/21/19 10:09 AM
Orange washer fluid?
by atikovi. 02/21/19 10:01 AM
Recommended laptop carrying case
by paulri. 02/21/19 09:47 AM
Collagen and Gelatin for protein supplement
by Lolvoguy. 02/21/19 09:36 AM
Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
113 registered members (Astro14, aircooled, atikovi, ABCarr, aquariuscsm, 13 invisible), 1,709 guests, and 55 spiders.
Topics284,605
Posts4,873,252
Members67,298
Most Online2,548
Feb 16th, 2019
Page 2 of 6 1 2 3 6
Re: 2000 Toyota Avalon [Re: clinebarger] #4887503
10/04/18 03:27 PM
10/04/18 03:27 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Keep us posted on the progress as you always give us great advice sir smile
Re: 2000 Toyota Avalon [Re: clinebarger] #4898943
10/17/18 06:06 PM
10/17/18 06:06 PM
Fort Worth, Texas
clinebarger Offline OP
Fort Worth, Texas
Progress has been a little slow.......
The engine passed a Leak-down with flying colors & Soaked all the pistons with GM upper engine cleaner....Though it probably didn't need it.
Pulled both valve covers to see if I had a slugded engine on my hands.....One of the cleanest 1MZ-FE's I've seen in a while!! The spark plug tube seals are in like new condition, So I left those alone & changed the valve cover gaskets.
This engine is out of a Camry or something similar (Different than a Avalon chassis anyway)......I have to change the Oil Pump as this engine uses a different timing belt tensioner set-up to clear a engine mount that the Avalon doesn't have. Special order from my local Toyota dealer.
It has a broken (Rear Bank) VVT solenoid from the engine removal, Probably going to order a new OE one cause I don't trust the one's in the car after being exposed to coolant.
I need to sell the U140E trans that came with this JDM engine (My Avalon has a A541E), No big deal if I don't as this package was cheaper than any high mileage wreaking yard pullout around here.
Some parts pics......I got the Radiator in after these were taken, $133 from the Toyota dealer which I thought was really good considering what OE Japanese radiators usually cost! Right now......I have $700 in parts & $550 in the engine package.
[Linked Image]
[Linked Image]
2001 Chevy Camaro L92/4L80E
Re: 2000 Toyota Avalon [Re: clinebarger] #4898945
10/17/18 06:08 PM
10/17/18 06:08 PM
Fort Worth, Texas
Fort Worth, Texas
Under the valve covers.....
[Linked Image]
[Linked Image]
Re: 2000 Toyota Avalon [Re: clinebarger] #4899148
10/17/18 11:50 PM
10/17/18 11:50 PM
KS
red7404 Offline
red7404  Offline
KS
i was driving my moms 2008 Avalon for 4 years she is in a care home. it was a good car. but i had to sale it. the ride was a bit to soft for me. had lots of power. i was putting 70% high way miles on it. about 700 miles a month. didnt need to many repairs. an Avalon is a good car if you like a soft ride. i tryed running the tire pressure up to 45. but that didnt work as the suspension didnt match.
Re: 2000 Toyota Avalon [Re: red7404] #4900709
10/19/18 08:46 PM
10/19/18 08:46 PM
Fort Worth, Texas
Fort Worth, Texas
Not a bad thing in this situation, This is for my wife & she still misses her old 1996 Pontiac Bonneville that rode on the soft side.
Re: 2000 Toyota Avalon [Re: clinebarger] #4900715
10/19/18 08:54 PM
10/19/18 08:54 PM
Fort Worth, Texas
Fort Worth, Texas
Got the oil pump installed, Along with the upper & lower oil pan cleaned & sealed-up. No sludge in the pan & the pick-up tube was clean.
[Linked Image]
Re: 2000 Toyota Avalon [Re: clinebarger] #4901161
10/20/18 12:11 PM
10/20/18 12:11 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Making great progress by the looks of it! I approve of the Ultra Gray sealing the lower pan and new oil pump. Did you have to pull the upper pan to change the pump or just the lower?
My 3MZFE went to its new owner with 190k on it, really a sweet engine, easy on oil and butter smooth and quiet.
Luke
Re: 2000 Toyota Avalon [Re: clinebarger] #4901328
10/20/18 04:16 PM
10/20/18 04:16 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Nice work. Your wife will love that Avalon.
Best kept Toyota secret.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2000 Toyota Avalon [Re: FlyNavyP3] #4901491
10/20/18 07:58 PM
10/20/18 07:58 PM
Fort Worth, Texas
Fort Worth, Texas
It's possible to swap the oil pump without removing the upper pan, But I would consider it less than ideal. I HATE oil leaks no matter how small.....Drives me nuts! So I pulled the upper pan.
Re: 2000 Toyota Avalon [Re: clinebarger] #4901530
10/20/18 08:45 PM
10/20/18 08:45 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Thanks for the update. I've never had to pull a pump on one of these so I wasn't sure if pulling the upper pan was required or just desired. I'm the same way I absolutely positively HATE oil leaks even of its just a weep. If the 341,000 mile rear main started weeping in my 4Runner tomorrow it wouldn't make it a week before I had the engine or transmission out to fix it.
Hope all is well.
Luke
Re: 2000 Toyota Avalon [Re: clinebarger] #4903462
10/22/18 08:36 PM
10/22/18 08:36 PM
Fort Worth, Texas
Fort Worth, Texas
Rounded up some bolts for the Timing Belt Tensioner......8mm-1.25 Main cap cross bolts from a LSx engine work perfectly! 10.9 grade as well.
[Linked Image]
Re: 2000 Toyota Avalon [Re: clinebarger] #4903466
10/22/18 08:37 PM
10/22/18 08:37 PM
Fort Worth, Texas
Fort Worth, Texas
Tensioner set-up that was on the engine......
[Linked Image]
Re: 2000 Toyota Avalon [Re: clinebarger] #4907920
10/27/18 09:00 PM
10/27/18 09:00 PM
Fort Worth, Texas
Fort Worth, Texas
Got a couple hours in on the project today.....I'm unusually busy for the time of year with this new job, When I was working on Race/Custom/Show cars, This was our slow time!
As soon as I get the time, I'll pull the engine out of the car. I need some parts off it to finish-up, Like the lower timing cover, Water outlet, & Power steering bracket.
Bank 1 VVT Solenoid is supposedly discontinued & my local Toyota dealer can't get one, I'm not about to use Dorman junk.....So I'll search for a NOS one, Or try to clean the one that in the car.
[Linked Image]
Re: 2000 Toyota Avalon [Re: clinebarger] #4907952
10/27/18 09:59 PM
10/27/18 09:59 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
This looks to be coming along nicely, i bet its going to run like new. You already know it but for the guys who don't. Ace hardware has a good selection of 10.9 and 12.9 metric bolts and nuts in regular hex and flange head along with hardened washers,
Some even have hardened stainless, good USA made stuff.
Re: 2000 Toyota Avalon [Re: clinebarger] #4908307
10/28/18 11:27 AM
10/28/18 11:27 AM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Wow, looking good!
Love the Snap-On hand tools, by the way.
I inherited a wonderful set from my older brother, who passed away in 1995 at 44.
He owned a 4 man shop in Santa Cruz, CA.
He used to tell me his job as owner was to keep the tools clean and lubed.
2018 Lexus RX450h
2006 Acura TSX
Page 2 of 6 1 2 3 6
Moderated by  ekpolk
