Originally Posted By: Tom777
Thanks for the feed back! Mine is the 09G that requires G 055 540 A2 and dealer is asking $24 a qt which will break my bank if i do a 12qt flush.
With regular drain-and-fills, you'll never need a flush. The cost for the entire service done at the dealer is reasonable when you're performing it per VW at 50k intervals.
Read up on the procedure before you attempt it yourself.
