The Kawasaki engine manual says use API SF, SG, SH, or SJ. Has one of those viscosity/temperature charts with the arrows for ranges. This chart shows 10W-30/10W-40 for temps -4 F to 95 F, 30 wt for 32F to 95F, 40 wt for 68F to 113F, and 5W-20 for -22F to 32F. Has a note at the bottom of the chart that says "Using multi grade oils will increase oil consumption. Check oil level more frequently when using them." Nothing else in the manual about oil except that it should be changed every 100 hrs with filter changed every 200. I will do oil and filter every 50 hours, or could do less if this forum feels 50 is too much.
I am in rural southern Illinois near St. Louis, MO and temps during the mowing season will typically range from about 40F to 95F, with an occasional hot period during the summmer around 100F or rarely up to 105-110F, and an occasional really cold leaf chopping in the fall with temps aroung 32F. Do not see a problem at the lower end, but will the 10W-30 be sufficient for the occasional hot periods?
I use Mobil 1 10W-30 in all of my cars and pickup, and Golden Spectro synthetic or semi-synthetic in the motorcycles, 2 stroke and 4 stroke. Now using 30W air cooled mower oil in the push mowers, tillers, generators, and pressure washer. Used to use Shell Rotella 30W and had some probs with oil consumption so switched to the specialty mower oil.
The air cooled mower oil does not seem like the right thing for the liquid cooled Kawasaki mower. I was considering the Mobil 1 10W-30, but just a little concerned about the short periods of 100F temps. I was wondering what the EP at the end of the Mobil you recommended means? Is that the longer oil change interval oil? Let me know what you think about all of this.
