Mitsuboshi Timing Belts
by artbuc - 08/21/19 04:02 AM
Veterans: Fram Ultra Select Sizes for 3.87$
by GumbyJarvis - 08/21/19 02:22 AM
P0455 Large evap leak on my G35
by bowlofturtle - 08/20/19 11:49 PM
Gen 2 ctsv...best oil opinion
by Stickygreen - 08/20/19 11:10 PM
Peak Global Lifetime in Grand Caravan
by Crispysea - 08/20/19 11:03 PM
Supertech "e-cores", ST2 and ST10575 question
by TheScarletRogue - 08/20/19 10:08 PM
Oil for my 2006 5.9 Cummins
by mobilaltima - 08/20/19 09:35 PM
Vise stand
by clinebarger - 08/20/19 09:29 PM
Ecoboost filter
by mpgo4th - 08/20/19 09:16 PM
Removing Sludge to Prevent Engine Failure?
by 04CorCar - 08/20/19 09:05 PM
ULSD and HPFP's
by sloinker - 08/20/19 08:54 PM
2018 Grand Caravan 1 year review
by tiger862 - 08/20/19 08:28 PM
The 10mm socket
by cwilliamsws6 - 08/20/19 08:12 PM
What Fuel is it?
by MolaKule - 08/20/19 08:01 PM
Oil stashes..
by Mad_Hatter - 08/20/19 07:49 PM
Sealing Redundant Door
by gathermewool - 08/20/19 07:25 PM
Cam2 Dexos1 Gen 2 found at Napa
by bbhero - 08/20/19 06:59 PM
Flywheel broke 2012 V8 Silverado, with pics
by 01rangerxl - 08/20/19 05:10 PM
Blade for brush cutter
by Donald - 08/20/19 04:47 PM
Al13, HughBeaumont, 04CorCar, reba, Dope
69013 Registered Users
31 registered members (CB900F2, 4WD, 08z06, ArrestMeRedZ, bismic1, 4 invisible), 767 guests, and 21 spiders.
Topics293,589
Posts5,042,956
Members69,013
Most Online3,532
Jul 30th, 2019
Page 3 of 3 1 2 3
Re: Picked up a new Glock 45 [Re: hatt] #4883748 09/30/18 12:49 PM
2015_PSD Offline
Originally Posted by hatt
Originally Posted by 2015_PSD
Originally Posted by bubbatime
Glock also says that the gen 5 guns blow the old pistols out of the water in long term reliability. According to them, the new guns are by far the most reliable they have ever made. So for me, the gen 3 was the gold standard legendary pistol, the gen 4 was mehhhh, and the gen 5 blows them out of the water.
The caveat to the Gen5 is it all good if you like it and if you are only seeking 9MM. Unless something has been changed since it was released with the Gen5 changes in the locking block, it cannot be used in higher pressure calibers. All of my Gen4 pistols are from 2016 and forward and have been nothing but reliable with two of them now pushing 12K in rounds down range. It will be interesting to see how the Gen5 fares, then again, what pistol from Glock has not ever paid for itself--for the company or the user?
9mm is a high pressure round. The most likely reason Gen5 guns are in 9mm because 9mm is super hot right now.
As compared to what? 10MM, .357SIG?
2019 Jeep Rubicon Wrangler Unlimited 3.6L V6 [OEM + Factory Fill]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Picked up a new Glock 45 [Re: 2015_PSD] #4883834 09/30/18 02:21 PM
H
hatt Offline
H
9mm +p is 38,500 psi. That's higher than SAAMI specs for .40 and 10mm. I think 357 Sig is 40,000 but 9mm is plenty high pressure. 9mm NATO may be higher than 40,000 but I don't remember. The only "low pressure" service round I can think of is .45 ACP.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Picked up a new Glock 45 [Re: hatt] #4884094 09/30/18 08:08 PM
2015_PSD Offline
[The caveat to the Gen5 is it all good if you like it and if you are only seeking 9MM. Unless something has been changed since it was released with the Gen5 changes in the locking block, it cannot be used in higher pressure calibers. All of my Gen4 pistols are from 2016 and forward and have been nothing but reliable with two of them now pushing 12K in rounds down range. It will be interesting to see how the Gen5 fares, then again, what pistol from Glock has not ever paid for itself--for the company or the user?
I read quite a bit about the Gen5 before it debuted and this is was stuck with me--particularly the bold parts. For me, it simply does not matter because I will not pick up any Gen 5 pistols, but for clarity, I think it is worthy of note:
First and second generation Glocks had triggers with only one pin in the locking block/trigger mechanism. A second pin, the locking block pin, was added to third generation pistols because the trigger pin alone wasn’t strong enough to deal with some cartridges [read: .40 cal] and displayed durability issues on high round-count pistols. Now with the fifth generation, the locking block pin has gone to live at the farm with the grip’s finger grooves. While this change might be a result of Glock improving the strength and design of the trigger bar and locking block components, we suspect that’s part of the story. Since Glock says the Gen5’s will only be offered in 9mm, the parts may not require the .40 cal reinforcement that came from the locking block pin.
Read more: http://www.recoilweb.com/inside-the-glock-gen-5-129141.html
Re: Picked up a new Glock 45 [Re: buck91] #4884633 10/01/18 02:46 PM
9
901Memphis Offline
9
Originally Posted by buck91
I saw this was released but got sidetracked before checking it out. So this is basically a combination of gen 5 19 and 17? Not sure I get that, as even with my large'ish meatpaws I can comfortably handle and shoot the 19/23. And I would want the extra barrel length and sight radius more, anyways. But I haven't handled one, perhaps I am mistaken?
The gun was designed for duty use straight up. When sitting in a car the shorter slide of the 19 doesn't bottom out on the seat as much on an OWB duty rig. The longer slide 17 is more uncomfortable for more people sitting in a patrol car. The longer grip is for 2 extra rounds which may or may not matter in a LEO involved shooting.
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Picked up a new Glock 45 [Re: LoneRanger] #4884635 10/01/18 02:47 PM
9
901Memphis Offline
9
Originally Posted by LoneRanger
Carry a 21F everyday on the job, great pistols but not a fan of the general way Glock's look. Rumor has it around work we may be going back to 9mm's. I hope not.
More capacity and easier follow up shots. If you can shoot a 21F well you can shoot the G19/17/45 even better i am sure. Never heard any complaints from officers using proper duty ammo, like 124+P Gold Dots, 124+P HST or 124+P Critical Duty.
Re: Picked up a new Glock 45 [Re: 2015_PSD] #4885299 10/02/18 09:15 AM
B
bubbatime Offline OP
B
Glock makes a .40 caliber Glock 22 on the 2 pin generation 5 frame. So apparently, they think the new 2 pin frame is just fine for .40 cal pressures. The locking block inside the gen 5 guns has 2 holes, for two pins, but obviously the frame only has one hole.
Sao Paulo Brazil police Glock 22 .40 with safety, generation 5
[Linked Image]
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Edge 0W40
06 GMC Sierra SuperTech 10W30
Re: Picked up a new Glock 45 [Re: bubbatime] #4885739 10/02/18 06:00 PM
2015_PSD Offline
Glock makes a .40 caliber Glock 22 on the 2 pin generation 5 frame. So apparently, they think the new 2 pin frame is just fine for .40 cal pressures. The locking block inside the gen 5 guns has 2 holes, for two pins, but obviously the frame only has one hole. Sao Paulo Brazil police Glock 22 .40 with safety, generation 5
The proof will be in the pudding if they make it in 10MM or .357SIG. In the end, it matters not to me because as I said, the Gen 5 offers nothing that would make me move away from my Gen 4's. Enjoy your pistol.
Re: Picked up a new Glock 45 [Re: Bottom_Feeder] #4894844 10/12/18 03:35 PM
B
Bottom_Feeder Offline
B
New forward slide serrations. Neither the 19 or 19X have that. Interesting.
They are releasing front serrations on their other two guns they just released as well. I dont know if this is a permanent change or not.
And no dumb finger hole in the grip for the mag. That's how my gen5 19 should have come from the factory instead of spending $30 for Pearce mag baseplates. Thanks a lot, Glock.
I finally took my gen 5 Glock 19 to the range. I must say I'm pretty disappointed at how uncomfortable the magwell cutout in the grip is even when using Pearce mag baseplates. They may actually make it worse. I guess I need to wrap my pinky finger with tape or band-aids or something next time. Lame.
Re: Picked up a new Glock 45 [Re: bubbatime] #4898685 10/17/18 12:46 PM
stchman Offline
Meh, another Glock that pretty much looks like all the other Glocks ever made.
2018 GMC Canyon Denali 4WD 3.6L
Harvest King Full Synthetic 5W-30
Fram CH10246
Page 3 of 3 1 2 3
