I am puzzled.
My car has a Torsen differential. This has some "Clutch Discs" ("Washers") and relies partly on friction for proper function. See attached pages from the Workshoip manual.
The owner manual only says "Use SAE 90 GL 5 Oil", no mention of LS Fluid.
Is it safe to use LS diff fluid in this type of differential or could this cause problems (To much fricton, harming the waschers, shearing the holding tabs of....) ?
