family member noticed the check engine light on but did not know how to read, interpret, or respond to the temperature gauge being pegged. continued to drive that way for another 30 minutes. when I got the car both radiator hoses were collapsed. thermostat stuck closed. likely it was stuck for the entire drive - which was 45 miles and almost an hour. I'm currently injured and could not do the work; a friend that did the work insists the head gasket is fine. I am suspicious. we will see. not sure how an engine could survive that amount of abuse. this engine has cast iron block and aluminum head.
