Wanted: Inexpensive car
by FirstNissan - 09/15/19 02:53 AM
Do all replacement LED headlight bulbs suck?
by Nick1994 - 09/15/19 12:56 AM
5 qt Chevron Supreme 5w-30 for $12.42 @ walmart.com
by gallydif - 09/15/19 12:03 AM
how effective is spray scotchgard?
by WhyMe - 09/14/19 11:39 PM
Want opinion of disc brake pad wear
by boulderdentist - 09/14/19 11:08 PM
Mercedes’ dealer oil filter panel/board
by SlavaB - 09/14/19 11:08 PM
Mercedes damage code
by SlavaB - 09/14/19 11:00 PM
Restoring the paint on the Crown Vic
by Colt45ws - 09/14/19 10:39 PM
Hyundai Ioniq
by WhyMe - 09/14/19 10:08 PM
Grooves in windshield due to wiper blades
by dx92beater - 09/14/19 09:43 PM
Valvoline Advanced Heavy-duty Oil Stabilizer
by Toh1 - 09/14/19 09:08 PM
The joys of air filters and the desert.
by Chris142 - 09/14/19 08:36 PM
Havoline Conventional 5qt $12.99 Menards
by Warstud - 09/14/19 08:12 PM
2017 Ford Escape Air Filter - 30,800 kms
by mcwilly - 09/14/19 07:33 PM
Jeep Grand Cherokee Trailhawks
by Lufty - 09/14/19 07:32 PM
Thinking about taking a flier on Toyo...
by dblshock - 09/14/19 06:18 PM
Exhaust donut leaking
by taztheman - 09/14/19 06:17 PM
Centrifuge and filtering effects on additives
by PapaSquat1 - 09/14/19 06:10 PM
Gbenitez, DoctorPc, FarmerDan, Vic61, Subicdoc
69275 Registered Users
23 registered members (FirstNissan, edyvw, Dave9, BlakeB, billt460, Deontologist, 4 invisible), 624 guests, and 18 spiders.
Topics294,553
Posts5,062,281
Members69,275
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4880390 09/26/18 08:30 PM
StevieC Offline
*Yawn* You done yet?
'18 Caravan - 42k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: StevieC] #4880428 09/26/18 08:53 PM
Shannow Offline OP
I'll re-iterate....smoking gun for what...?
The paper is about..."the effects of Viscosity on Heavy Duty Engine Components".
If it's the truth....it can handle the pressure !!!
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4880458 09/26/18 09:12 PM
N
nap Offline
N
Here’s a different one
https://www.sciencedirect.com/science/article/pii/S0301679X15003709
that may have the effect of rejoicing the thin camp. The thicker oil produced less iron but sensibly more lead in the UOA.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: StevieC] #4880633 09/27/18 03:24 AM
Z
ZeeOSix Offline
Z
Originally Posted by StevieC
Originally Posted by Shannow
Yeah, you stated in the other thread(s) that as the studies aren't all engines and all circumstances, that they were equivalent to wild suppositions based on imagined engines, and imagined operational circumstances.
I disagree.
As I said in the other thread. Does it warrant more investigation sure, is it a smoking gun for all situation absolutely not.
It doesn't need "more investigation" ... it's been studied and tested for decades and the conclusion is still pretty much the same - higher viscosity/higher HTHS typically gives better wear protection.
Saying that the studies and their conclusions don't have any merit because it hasnt been "tested in every engine in every circumstances" known to exist in the world is another strawman argument.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: nap] #4880636 09/27/18 03:40 AM
Z
ZeeOSix Offline
Z
Lots of miles (km) on those oil runs - and the wear deviation starts showing up after 10 km. Did they take KV100 and HTHS readings as the miles piled up to see if the 10W-40 sheared down below the 5W-30? Lead wear would be journal bearings I would assume.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: ZeeOSix] #4880843 09/27/18 09:13 AM
N
nap Offline
N
The explanation offered by the authors is "The most feasible explanation could be linked to additive depletion. For oil B, after 20,000 km anti‐wear additives have been almost absolutely depleted (FT‐IR measurements have been performed to assess this situation) and an acidic attack against Babbitt metals appears leading to the situation previously mentioned. In the case of the LVO, the higher content of anti‐wear additives, let to obtain a longer period of usage where this corrosive wear is under control, obtaining very low lead wear rates."
Which may lead someone to be cautious with the latest iterations of consumer oil standards.... laugh
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: nap] #4881276 09/27/18 04:08 PM
Shannow Offline OP
nap, really good dot point that...additives at work.
It's consistent with the start-up wear statements here
https://www.sae.org/publications/technical-papers/content/600190/
Predominantly corrosion, not "flow"
I've posted stuff on hastening warmup before, think this, but will have to scout through the library over the weekend.
https://www.sae.org/publications/technical-papers/content/2011-01-0318/
(But suffice to say that thicker oil will heat faster...LOL)
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4890545 10/08/18 01:26 AM
Silk Offline
So, would the oil heat up faster in say a 7 bearing 6, as opposed to a 3 bearing crank 4 cyl of similar capacity ? Of course the 4 cyl is going to have larger journals which could just make it the same anyway.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Silk] #4892469 10/10/18 03:24 AM
Shannow Offline OP
Would say so...look at the bottom end of a slant 6, or 4 main ford versus the 7 bearings, and the mains aren't materially larger in total dimension than the 7s.
But the piston skirt area is a pretty big "bearing" area for heat to e generated, diminishing the effect of the mains.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4893037 10/10/18 02:52 PM
CR94 Offline
Uh ... haven't 4-bearing in-line Sixes been obsolete for a very long time (a little less long for the Slant Six)? 3-bearing in-line Fours, too? GM, Ford, and AMC all switched to then-new 7-bearing Sixes in the early- to mid-1960s in the US.
2011 Toyota Prius now at 102K
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: CR94] #4893273 10/10/18 06:31 PM
Shannow Offline OP
Was still a valid question, worth answering...
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4893536 10/11/18 02:04 AM
Silk Offline
In my mind I had a 149 Holden and a large British 4 cyl...large BMC, Rootes and Standard were still made at that time the 7 bearing Holden came out. There just seems to be a lot more going on in an inline 6 than a 3 bearing 4 to heat up oil. What's obsolete got to do with anything ?
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4901760 10/21/18 08:36 AM
Cujet Offline
Decades ago, engineers learned that direct measurement was required when testing wear rates. UOA's, while helpful, do not reflect individual wear rates.
I worked for Mobil OIl in their flight department. I worked with the Mobil engineers on SHC100 grease testing and on Mobil 245 turbine engine oil. This was real world testing on Mobil Oil's flight department fleet. With very specific testing protocols. The scanning electron microscope and other forms of very precise measurement were the best ways to determine wear rates.
I was a young guy and always found time to chat with the engineers about the processes and results. It was amazing to see how they could accurately determine bearing wear rates on perfectly serviceable bearings.
What we consider UOA; mass spectrometry, was interesting information, but did not reflect real world wear, and especially wear of individual components.
Page 2 of 2 1 2
