Trying to figure out how to separate the power steering pump (fluid) from the steering rack but keep the pump pulley lubricated for the serpentine belt.
The intent of this is for the mid-2000s years Volvo 2.5T engine, but it's applicable to most engines.
People remove, bypass, delete the power steering on their cars for various reasons. It's easy to do on an engine that has a separate pulley belt for each accessory. And easy to do on serpentine-belt vehicles that can remove the pump entirely and use a shorter serpentine belt. And on vehicles with aftermarket support to remove the pump and replace with just an aftermarket pulley to take the pump's place.
But what to do on other vehicles? If power steering pumps put out a high psi on the outlet line, is it ok to just remove the line and screw a plug into the pump to seal it off? (and keep the feed line from the power steering fluid reservoir intact to keep the pump lubricated.) The high pressure from the now-plugged outlet line shouldn't damage the pump internals, should it?
Does the pump even output much pressure when the wheels aren't being turned? If not, then plugging the output hole would just keep it in low-load mode all the time.
I've also heard of people taking pumps apart and removing the vanes or similar from the internals, so the pulley still spins, but the fluid inside the pump isn't being pumped at all. I'd rather just screw a plug in where the output line was though, if the high pressure won't hurt it.
