I don't think that's M1 0w-40 either. Visc is wrong, moly is wrong.
It should look like Astro's:
https://www.bobistheoilguy.com/foru...0-4945-mi-mercedes-s600-m275#Post4870770
Or any of the other recent M1 0w-40 UOA's.
Unless the lab completely mixed up the sample with someone else's, it is definitely M1 0W-40. I have not been impressed with M1 in my AMG either and switched to Castrol 0W-40. I installed Pennzoil Euro 0W-40 in the C300 this time.
Then I would follow up with the lab. The moly level is completely wrong, visc is too high and the rapid TBN depletion all point to this not being an analysis of that oil.
I 2nd getting a VOA of it if you have more. Where did you buy it from?
I bought it at Walmart, but have none left and will not buy more. My hope is the Pennzoil and Castrol are better oils.
Was the seal intact? This reminds me of the goo in the pan thread, remember that one?
Any approved lubricant should perform similarly and as you may have noted, Astro14 had excellent results with M1 0w-40, as have I. Be interesting to see what the labs says about this, as either you unknowingly weren't running M1 0w-40, or this isn't your sample.
