Sharing files
by Chester11. 06/17/19 03:25 PM
Fumoto valves
by cwilliamsws6. 06/17/19 03:12 PM
Who goes to beaches for vacation?
by 53' Stude. 06/17/19 02:35 PM
What would make BITOG better?
by Hastrup. 06/17/19 01:44 PM
Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
Saab 9-3 Carrier Bolts - 155 ft lbs
by ET16. 06/17/19 09:15 AM
Fran CA11480
by jcartwright99. 06/17/19 08:43 AM
Recommend oil for 2020 Kia Soul 2.0L
by Hoot_r. 06/17/19 08:40 AM
Why does Amsoil market the way it does?
by Redright9. 06/17/19 08:36 AM
'11 CTSV - M1EP 10w30 - 8K Built LSA - ~2k sample
by oilnoob32. 06/17/19 08:34 AM
Blue smoke and Mobil 1 Syn High Milage!!
by Kestor. 06/17/19 08:03 AM
crank and water pump pulleys stuck
by slybunda. 06/17/19 07:50 AM
Skraeling, Metalmanx48, Cannedcreamcorn, Kestor, Slipcase
68418 Registered Users
94 registered members (2011335d, 53' Stude, 1978elcamino, 2012AccentSE, 10 invisible), 2,423 guests, and 29 spiders.
Topics290,580
Posts4,988,811
Members68,418
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: HydroGear factory fill EZT-2200 UOA [Re: SOHCman] #4865820
09/11/18 05:40 AM
09/11/18 05:40 AM
PA
Patrick0525 Offline OP
PA
Originally Posted by SOHCman
The word on the street is hydro units love ZDDP, zinc in particular. Exmark used to only recommend M1 15w-50, but ever since Mobil lowered the zddp levels in it they had to start offering their own Exmark branded fluid. No idea who actually makes it but its alleged to be loaded with zinc.
Amsoil Hydrostatic Transmission zddp levels. https://bobistheoilguy.com/forums/ubbthreads.php/topics/4865819#Post4865819
'14 Toyota Venza 3.5L 88K mi
TGMO 0W-20
PP 0W-20/Fram Ultra filter(spring/summer)
Re: HydroGear factory fill EZT-2200 UOA [Re: Patrick0525] #4878178
09/24/18 09:27 PM
09/24/18 09:27 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Was this the factory fill?
If there are no babbit bearings, and it appears they are using only roller bearings, the lead must have come from a chemistry component added at the factory, most likely Lead(2+) di(2-naphthoate).
Since there appears only to be spur gears involved, ZDDP levels of 700 ppm are sufficient. No need for EP additives.
The analyzed oil appears to about an 80W90.
E = M*C^2; I.e., Energy = Milk*Coffee^2
Re: HydroGear factory fill EZT-2200 UOA [Re: MolaKule] #4878205
09/24/18 09:56 PM
09/24/18 09:56 PM
PA
PA
Yes, this is a factory fill on my Club Cadet ZTR.
TGMO 0W-20
Re: HydroGear factory fill EZT-2200 UOA [Re: Patrick0525] #4963925
12/28/18 10:57 PM
12/28/18 10:57 PM
ms
racinjason Offline
racinjason  Offline
ms
Just did a set of ezt’s on a 5 of 2012 rzt50. What came out looked like gear oil to me. The noisy side had a foul odor.
I put couple capfuls of Lucas assembly lube in each, filled with Napa 15w-50 and it’s pretty quiet now.
I pulled them, flipped them, refilled. Vents were clear, no water I could see.
Page 2 of 2 1 2
