Powerstop Brake kits
by RhondaHonda - 10/14/19 03:00 PM
Oil recommendations
by Speak2Mountain - 10/14/19 02:28 PM
Maxlife ATF
by charmer37 - 10/14/19 02:18 PM
Anyone want a NAPA GOLD 1334 and FRAM ULTRA 3593A
by 53' Stude - 10/14/19 01:59 PM
Sams Choice Cuban Style Mustard
by skyactiv - 10/14/19 01:55 PM
Front suspension still making noise
by A_A_G - 10/14/19 01:20 PM
What is this? It says SmartGear
by JLawrence08648 - 10/14/19 12:20 PM
2004 Toyota Sienna
by Char Baby - 10/14/19 11:48 AM
Installing your own winter tires
by Snagglefoot - 10/14/19 10:43 AM
2018 Subaru Forester Premium 11mo Review
by badtlc - 10/14/19 10:40 AM
Good price on Mobil 1 Delvac 75w-90?
by kehyler - 10/14/19 09:09 AM
Ford IDI diesel starters
by bullwinkle - 10/14/19 09:07 AM
Portable Induction Bolt Heater
by billt460 - 10/14/19 06:51 AM
Coil springs, is there a top and bottom?
by LeakySeals - 10/14/19 06:20 AM
Non-DPF engine oil in Diesel BMW F10
by L93013 - 10/14/19 04:00 AM
Mercedes, Worth It?
by rrretiree7 - 10/14/19 02:30 AM
Using Marine Gear Oil in a Tractor
by Hot_Ajax - 10/14/19 12:53 AM
HotelPrisoner, Germanium, ffr1222k, Laurie, messerschmitt
69554 Registered Users
101 registered members (benhen77, A310, Anduril, Audios, aquariuscsm, 9 invisible), 2,557 guests, and 40 spiders.
Topics295,960
Posts5,088,154
Members69,554
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: HydroGear factory fill EZT-2200 UOA [Re: SOHCman] #4865820 09/11/18 05:40 AM
P
Patrick0525 Offline OP
P
Originally Posted by SOHCman
The word on the street is hydro units love ZDDP, zinc in particular. Exmark used to only recommend M1 15w-50, but ever since Mobil lowered the zddp levels in it they had to start offering their own Exmark branded fluid. No idea who actually makes it but its alleged to be loaded with zinc.
Amsoil Hydrostatic Transmission zddp levels. https://bobistheoilguy.com/forums/ubbthreads.php/topics/4865819#Post4865819
2014 Toyota Venza 2GR-FE 93K mi
2009 Lexus ES350 2GR-FE 49K mi
Fram Ultra filter XG9972
TGMO or Idemitsu Zepro 0w20 (winter)
PP 0w20 (spring/summer/fall)
Re: HydroGear factory fill EZT-2200 UOA [Re: Patrick0525] #4878178 09/24/18 09:27 PM
MolaKule Offline
Global Moderator
Global Moderator
Was this the factory fill?
If there are no babbit bearings, and it appears they are using only roller bearings, the lead must have come from a chemistry component added at the factory, most likely Lead(2+) di(2-naphthoate).
Since there appears only to be spur gears involved, ZDDP levels of 700 ppm are sufficient. No need for EP additives.
The analyzed oil appears to about an 80W90.
"You ... sadist," said Mr Cummings, "you try to make people think." Ezra Pound (1885-1972)
Re: HydroGear factory fill EZT-2200 UOA [Re: MolaKule] #4878205 09/24/18 09:56 PM
P
P
Yes, this is a factory fill on my Club Cadet ZTR.
Re: HydroGear factory fill EZT-2200 UOA [Re: Patrick0525] #4963925 12/28/18 10:57 PM
R
racinjason Offline
R
Just did a set of ezt’s on a 5 of 2012 rzt50. What came out looked like gear oil to me. The noisy side had a foul odor.
I put couple capfuls of Lucas assembly lube in each, filled with Napa 15w-50 and it’s pretty quiet now.
I pulled them, flipped them, refilled. Vents were clear, no water I could see.
Page 2 of 2 1 2
