Using an upper cylinder lube for lean running engine?
by dunlop0078 - 02/20/20 01:45 PM
New Ford Escape...1.0 liter...really?
by grampi - 02/20/20 01:34 PM
I need information on these filters
by 4fordsd - 02/20/20 01:18 PM
WashZilla
by John_Conrad - 02/20/20 12:56 PM
Continental WinterContact TS870
by SubLGT - 02/20/20 12:52 PM
What sort of ATF and is Merc V synthetic?
by Stinky123 - 02/20/20 12:37 PM
Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
130 registered members (Ag76, 28oz, 4fordsd, antone, advocate, 2young2retire, 15 invisible), 2,076 guests, and 17 spiders.
Topics301,704
Posts5,200,973
Members70,759
Glass Scrub? #4877948 09/24/18 04:03 PM
B
buck91 Offline OP
B
So I've been using this bottle of Glass Science Glass Scrub for a while and it seems to work VERY WELL. I use it before applying the same company's "Rain Clear" and when used together like this it lasts an INCREDIBLY long time (like, I literally get a year or more between reapplications). Has anybody heard of this? Nothing on Amazon or Autogeek; looks like its been renamed to Glass Renew by the manufacture... Sure would like to know where to source some more when I run out of these two products!
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Glass Scrub? [Re: buck91] #4877957 09/24/18 04:11 PM
SnowDrifter Offline
I clay bar my windshield and lay down a coat of aquapel at the start of winter. Begins to wear off at the end of summer before I redo it
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Glass Scrub? [Re: buck91] #4877959 09/24/18 04:13 PM
T
Trav Offline
T
The 1886 and only the 1886, any other can scratch the glass. The best there is..
https://www.acehardware.com/departm...-disinfectants/scouring-cleaners/1487503
Re: Glass Scrub? [Re: Trav] #4877990 09/24/18 04:57 PM
E
ET16 Offline
E
Agree! It's hard to find, though.
Re: Glass Scrub? [Re: buck91] #4877997 09/24/18 05:10 PM
N
NoNameJoe Offline
N
Rain-X makes something called Rain-X Xtreme Clean, which is basically a gel/paste you squeeze out consisting of soapy stuff plus aluminum oxide, which is enough to scrub contaminants off of glass but not the glass itself. I've been using it for years and it's readily available at your local Walmart.
If you use it with a power tool (like an orbital) it goes to town. Every time I wash and wax the car I use it. Gets all of the crap off the windshield plus removes old Rain-X too if you want to remove that for some reason. Then I follow it up with fresh Rain-X.
https://www.rainx.com/product/glass-water-repellents-cleaners/rainx-xtreme-clean/#.W6lujvZFxGM
2015 Civic LX Coupe
Re: Glass Scrub? [Re: buck91] #4878058 09/24/18 06:06 PM
Carmudgeon Offline
Those products are made by Unelko Corp., the company that invented Rain-X.
After they sold R-X to SOPUS, they continued to market glass care products under that brand. O'Reilly used to carry them, but hasn't for a while.
The original feldspar 1886 formula Bon Ami can leave micro scratches in glass as well, if used regularly.
Re: Glass Scrub? [Re: NoNameJoe] #4878090 09/24/18 06:38 PM
G
Garak Offline
G
I do like that stuff. It's not even necessary to use it often.
Plain, simple Garak.
Re: Glass Scrub? [Re: Carmudgeon] #4878115 09/24/18 07:02 PM
T
Trav Offline
T
I suppose anything can scratch glass if you are not gentle. I do it once a month or so, wet the windshield first, sprinkle a small amount and wipe it gently with a microfiber sponge not scrub it like I am trying to remove a layer of paint.
No visible micro scratches at nigh .
Ace hardware usually doesn't have it in stock but they do carry it and will order it for you to pick up in store with no shipping charges, they also have Sno Seal cheap if you order it.
Re: Glass Scrub? [Re: Trav] #4878166 09/24/18 08:14 PM
justintendo Offline
sno seal! love that stuff..been using it ever since my father taught me how to treat my boots. laces out, scrub clean and dry...then turn the oven on low, pou the boots in and pull em out one at a time and melt that stuff in.
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: Glass Scrub? [Re: justintendo] #4878214 09/24/18 09:10 PM
T
Trav Offline
T
Yep, its great. Never get wet boots with this stuff, even the old boots that otherwise take on water like a sponge stay dry.
