For a few years now, the defrost function in this car had been poor. No matter what mode I'd set the HVAC panel on, air would mostly flow out of the dashboard vents. Not the greatest situation on a icy winter day!
After snaking an inspection camera down the vents, the problem was obvious: the door that controls the vent airflow had broken from it's hinge, not allowing it close when needed.
It's not an incredibly common failure with these vehicles, but it's not unheard of either. Rather than using a real mechanical hinge, the door is attached to a flexible piece of plastic that breaks over time.
The fix? Dashboard removal and plenum replacement! really taking my time and waiting for some help to haul the dashboard in/out of the car, it took 5 hours start to finish. Pics in case anyone else needs a visual reference when tackling panther body HVAC problems.
