My Son's 2008 Malibu has some condensation in both headlights and although I have watched some Youtube vids on how to go about it, is there anything else I should be doing as far as not having to deal with this issue again?
Most vids show finding the spot where moisture/water is getting in then caulking/sealing that with weather proof silicone. I was thinking, before I watched the vids, that I'd separate the front lens from the back plastic housing, clean everything up really good then silicone them back together.
Is that overkill or should I stick with this plan?
These guys don't do that so maybe I should just stick with the easiest way?
