What would make BITOG better?
by Hastrup. 06/17/19 01:44 PM
Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
Saab 9-3 Carrier Bolts - 155 ft lbs
by ET16. 06/17/19 09:15 AM
Fran CA11480
by jcartwright99. 06/17/19 08:43 AM
Recommend oil for 2020 Kia Soul 2.0L
by Hoot_r. 06/17/19 08:40 AM
Why does Amsoil market the way it does?
by Redright9. 06/17/19 08:36 AM
'11 CTSV - M1EP 10w30 - 8K Built LSA - ~2k sample
by oilnoob32. 06/17/19 08:34 AM
Blue smoke and Mobil 1 Syn High Milage!!
by Kestor. 06/17/19 08:03 AM
crank and water pump pulleys stuck
by slybunda. 06/17/19 07:50 AM
2018 Mazda6 oil choice?
by gabriel9766. 06/17/19 07:33 AM
The Real Scoop
by RayCJ. 06/17/19 06:08 AM
time based timing belt change question
by berniedd. 06/17/19 03:18 AM
Skraeling, Metalmanx48, Cannedcreamcorn, Kestor, Slipcase
68418 Registered Users
103 registered members (2015_PSD, 69Torino, 53' Stude, 2011335d, 2012AccentSE, 11 invisible), 2,361 guests, and 28 spiders.
Topics290,577
Posts4,988,746
Members68,418
Most Online2,967
Mar 10th, 2019
Michelin jack won't lift a load #4876379
09/23/18 01:32 AM
09/23/18 01:32 AM
Avondale
10WSmuckers Offline OP
Avondale
Hi all. I have a 3 1/2 ton Michelin floor jack that has the quick lift feature but it has now rendered itself useless. It will raise and lower itself without any weight on it but anything like a car is out of the question. It will just stay under the car and squeak loudly with every pump. There are 3 screws behind the pump cylinder and I don't want to risk adding more air into what I suspect isn't the oil fill plug. In fact they say "DO NOT ADJUST" around these 3 plugs and this isn't something I want to mess up completely. How can I bleed the air out thoroughly?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876420
09/23/18 05:21 AM
09/23/18 05:21 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
It IS messed up completely. It doesn't work.
How do you imagine you are going to make that worse?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876435
09/23/18 06:35 AM
09/23/18 06:35 AM
NH
wdn Offline
wdn  Offline
NH
Good reason why top brands should never license their brand name to put on other random stuff that is not made by them. I hope my Kubota shop vac holds up.
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876453
09/23/18 07:21 AM
09/23/18 07:21 AM
ME
eljefino Offline
eljefino  Offline
ME
Take it all apart and look for shot o-rings.
Re: Michelin jack won't lift a load [Re: eljefino] #4876469
09/23/18 07:52 AM
09/23/18 07:52 AM
out there
spasm3 Offline
spasm3  Offline
out there
You have nothing to lose by doing this. Its shot either way.
I'd watch this and give it a try.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876503
09/23/18 08:19 AM
09/23/18 08:19 AM
Michigan
jkasch Offline
jkasch  Offline
Michigan
If you haven't yet, try this first.
Bleeding
1. Remove the Cover Plate.
2. Loosen the Fill Screw.
3. Turn the Handle counterclockwise to open the Release Valve.
4. Pump the Handle up and down quickly several times to purge air from the system.
5. Check oil level and add as explained below, if needed.
6. Tighten the Fill Screw and replace the Cover Plate.
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876565
09/23/18 09:59 AM
09/23/18 09:59 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
How old is the jack?
2015 F150 2.7
2018 F350 6.2
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876649
09/23/18 11:26 AM
09/23/18 11:26 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would even try to fix it, its a cheap Chinese jack with a brand name from a company that doesn't even make jacks. Return it of toss it IMHO.
Jacks can be dangerous if they fail. If it were a good brand I would have the cylinder serviced by the company.
Re: Michelin jack won't lift a load [Re: Trav] #4879770
09/26/18 11:30 AM
09/26/18 11:30 AM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
China can copy and produce hard parts pretty well, it's the rubber compounds they have trouble with. I bought a cheap Chinese jack back in the 80s and within the first year it started to fail/leak, not surprising. So, being an aircraft mechanic, I headed over to see my friend in the hydraulics shop. He fixed me up with new o-rings, seals and backups and that jack is still going strong today. Now, do I trust my life with it? Heck no! I never crawl under a vehicle without jack stands in place and the weight relieved from the jack.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
