Consumer Report full size trucks
by kstanf150. 06/16/19 01:29 PM
Woes of an aging Hyundai
by Fifth87. 06/16/19 01:08 PM
Happy Father's Day
by dave1251. 06/16/19 12:42 PM
Filter Forum rules
by dnewton3. 06/16/19 12:09 PM
My daughter shooting
by Eosyn. 06/16/19 12:04 PM
Window Privacy Film (Tint)
by Warstud. 06/16/19 11:52 AM
Anyone got a Fireworks stash?
by Vern_in_IL. 06/16/19 11:25 AM
Oil Themed Tool Kit
by javacontour. 06/16/19 10:41 AM
Carfax reveals cursed vehicle
by Elkins45. 06/16/19 09:38 AM
We love our ethanol!
by SevenBizzos. 06/16/19 09:36 AM
LSPI Event - ?
by josephp732. 06/16/19 08:39 AM
'09 Honda Metropolitan hit 15k this morning
by Lawn_Care. 06/16/19 08:17 AM
16 y/o car w/98k, switch oil?
by Ricky_Samsonia. 06/16/19 08:13 AM
Ultrasonic Cleaner
by ET16. 06/16/19 06:27 AM
Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
73 registered members (BigCahuna, ARCOgraphite, atikovi, Al, BeerCan, 5 invisible), 2,136 guests, and 27 spiders.
Topics290,276
Posts4,987,521
Members68,413
Most Online2,967
Mar 10th, 2019
Synthetic for a 30 year old engine? #4876372
09/23/18 01:02 AM
09/23/18 01:02 AM
California
geissjr Offline OP
geissjr  Offline OP
California
I just purchased a 1989 Camaro with 67k original miles. The owner has serviced the car well, but has always used conventional oil. Can I convert to synthetic or is this going to cause problems? Thank you.
2015 GMC Sierra M1 0w-20
2016 Mercedes Benz GLE M1 0w-40
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876373
09/23/18 01:06 AM
09/23/18 01:06 AM
South Wales, UK
Bailes1992 Offline
Bailes1992  Offline
South Wales, UK
You'll be fine. Maybe look at a high mileage oil or using an additive with seal conditioners just incase.
'17 Volvo V40 D3 Geartronic - Castrol Edge 5w30 LL
'19 Dacia Sandero 0.9T - Shell Helix Ultra 5w40
'96 LR Defender 300TDi - Morris Lubricants HD4 15w40
'12 BMW 320d Sport Auto - Fuchs GT1 5w40
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876374
09/23/18 01:11 AM
09/23/18 01:11 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Why?
2015 F150 2.7
2018 F350 6.2
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876384
09/23/18 01:52 AM
09/23/18 01:52 AM
Balearic Islands , Spain
FordCapriDriver Offline
If the seals and gaskets are in good shape and the car has been generally maintained well then yeah no problem i guess.
On an engine that leaks oil, and is cruddy inside i would not.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40
G40 Si-OAT coolant in both
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876385
09/23/18 01:56 AM
09/23/18 01:56 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
At 30 years old, I don't see the point. Are you going to be putting a ton of miles on it?
Unless the gaskets have been changed recently, I wouldn't bother.
Although I do run a 1970 VW Beetle on synthetic, but it's already got oil leaks everywhere, it's parked in gravel, and sees very low mileage.
2015 Hyundai Sonata 2.4L 96k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 234k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876396
09/23/18 03:00 AM
09/23/18 03:00 AM
MT
jongies3 Offline
jongies3  Offline
MT
Stick with what's worked for the past 30 years!
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: PYB 10W-30, FRAM COR3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876409
09/23/18 04:12 AM
09/23/18 04:12 AM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
Put in conventional oil once. Run it a few hundred miles. Look for leaks and loss of (burning) oil. You can't go by what came in it when sold to you, might just be high viscosity goop meant to quiet the engine.
Anyway with the correct conventional in you have a baseline. If seals are leaking, switching to synthetic will probably make it worse with all else equal, but you can use high mileage synthetic with seal conditioners.
If the seals are not leaking with conventional oil, do not put high mileage conventional or synthetic in. It does nothing good for seals until they start leaking.
If you switch to synthetic and THEN it starts leaking, I'd top it off with high mileage oil and switch to 50% high mileage oil on the next change, not using more of the stuff than needed to keep leaks under control.
Shorter answer: Sure it's a good idea to switch to synthetic but don't try to drop down to 5W-20 because the engine is designed for 10W-30 or thicker.
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876413
09/23/18 04:23 AM
09/23/18 04:23 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yes, you can switch to synthetic oil. Will you have leaking issues? It remains to be seen.
Since the engine has been well maintained according to the previous owner, there shouldn't be any sludge in the engine therefore, the synthetic oil shouldn't have any sludge to remove which could cause some future oil leaking!
My 38 year old Firebird V8 engine has ONLY used conventional oil all of it's life but, I don't drive it hard.
However, with most conventional & high mileage oils now being a synblend, I guess I am using some syn oil.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Synthetic for a 30 year old engine? [Re: Dave9] #4876419
09/23/18 05:00 AM
09/23/18 05:00 AM
South Wales, UK
Bailes1992 Offline
Bailes1992  Offline
South Wales, UK
Disagree with the high mileage oil.
The seals conditioners help to ensure the old seals are elastic and pliable. Regardless of oil leaks or not they're worthwhile on older cars!
Agree with the viscosity. Keep the same operational viscosity. I.e. if you're using a 15w40 you could go for Castrol Edge 0w40.
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876431
09/23/18 06:16 AM
09/23/18 06:16 AM
Mississippi
Speak2Mountain Offline
Mississippi
I'd run PYB or Castrol UltraClean 1st and check for leaks. If no leaks, I'd go Walmart SuperTech 10w30 Syn.
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876465
09/23/18 07:44 AM
09/23/18 07:44 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Castrol GTX 5W30
Me: 13' VW GTI 3 door 6 speed manual
Re: Synthetic for a 30 year old engine? [Re: jongies3] #4876468
09/23/18 07:49 AM
09/23/18 07:49 AM
Kitty Hawk, NC
NormanBuntz Online content
NormanBuntz  Online Content
Kitty Hawk, NC
Yup.
2013 Honda Accord LX, 61K
2007 Honda Ridgeline RTS, 90K
2007 Infiniti M35, 109K
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876491
09/23/18 08:12 AM
09/23/18 08:12 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
No need for the syn, Im pretty sure even the conventional will have some syn in it. Id go with a VWB or PYB in 10/40 or so to start, maybe try a high mileage like said. Dont over think it! The car ran on conventional for a long time, Im sure its happy with the same stuff going back in.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876519
09/23/18 08:57 AM
09/23/18 08:57 AM
South Carolina
ka9mnx Offline
ka9mnx  Offline
South Carolina
I changed to sythetic oil in my: 1993 F150 at 182K (now at 255K), 1997 B2500 Van at 160K (now at 175K) and 2000 4Runner at 245K (now at 250K). No leaks. No problems.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Synthetic for a 30 year old engine? [Re: geissjr] #4876531
09/23/18 09:15 AM
09/23/18 09:15 AM
California
SavagePatch Offline
SavagePatch  Offline
California
Sounds like the compromise to meet in the middle of all the suggestions above would be Maxlife Synblend 10w30. It'd be hard for me not to spend the extra couple of bucks and use the full synthetic version though.
