Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
New Battery --> Group 25 (stock), 24 or 34???
by gathermewool - 04/01/20 12:49 PM
Tell this geezer why I need gigabit Internet?
by csandste - 04/01/20 11:48 AM
Wiring up a 240vac hour meter to air compressor?
by motor_oil_madman - 04/01/20 11:04 AM
BMW 328D?
by meep - 04/01/20 10:19 AM
A moment of silence...😟
by Mad_Hatter - 04/01/20 09:20 AM
Shaving costs during this time
by Bighorn2500 - 04/01/20 08:25 AM
Bosch Premium 3410
by QuangTeo - 04/01/20 03:48 AM
Thicker oils are coming back to USA
by Kamele0N - 04/01/20 03:07 AM
misty air coming out of air hose even with water separator?
by motor_oil_madman - 03/31/20 11:22 PM
Post your favorite racing cars
by IMSA_Racing_Fan - 03/31/20 09:40 PM
Air Filters for Chonda 457cc engine
by 92saturnsl2 - 03/31/20 07:59 PM
Share your Hot Toddy recipe
by LoneRanger - 03/31/20 07:24 PM
junipertoxic, mtnrider, Rickborn, TreyT42, Abi
71070 Registered Users
90 registered members (53' Stude, 4WD, 64bawagon, 1978elcamino, 14Accent, 2K2AcuraTL, 9 invisible), 2,149 guests, and 17 spiders.
Topics303,431
Posts5,235,236
Members71,070
Michelin jack won't lift a load #4876379 09/23/18 01:32 AM
1
10WSmuckers Offline OP
1
Hi all. I have a 3 1/2 ton Michelin floor jack that has the quick lift feature but it has now rendered itself useless. It will raise and lower itself without any weight on it but anything like a car is out of the question. It will just stay under the car and squeak loudly with every pump. There are 3 screws behind the pump cylinder and I don't want to risk adding more air into what I suspect isn't the oil fill plug. In fact they say "DO NOT ADJUST" around these 3 plugs and this isn't something I want to mess up completely. How can I bleed the air out thoroughly?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876420 09/23/18 05:21 AM
Ducked Offline
It IS messed up completely. It doesn't work.
How do you imagine you are going to make that worse?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876435 09/23/18 06:35 AM
W
wdn Offline
W
Good reason why top brands should never license their brand name to put on other random stuff that is not made by them. I hope my Kubota shop vac holds up.
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876453 09/23/18 07:21 AM
E
eljefino Offline
E
Take it all apart and look for shot o-rings.
Re: Michelin jack won't lift a load [Re: eljefino] #4876469 09/23/18 07:52 AM
spasm3 Offline
You have nothing to lose by doing this. Its shot either way.
I'd watch this and give it a try.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876503 09/23/18 08:19 AM
J
jkasch Offline
J
If you haven't yet, try this first.
Bleeding
1. Remove the Cover Plate.
2. Loosen the Fill Screw.
3. Turn the Handle counterclockwise to open the Release Valve.
4. Pump the Handle up and down quickly several times to purge air from the system.
5. Check oil level and add as explained below, if needed.
6. Tighten the Fill Screw and replace the Cover Plate.
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876565 09/23/18 09:59 AM
CT8 Online Content
Online Content
How old is the jack?
2015 F150 2.7
2018 F350 6.2
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876649 09/23/18 11:26 AM
T
Trav Offline
T
I would even try to fix it, its a cheap Chinese jack with a brand name from a company that doesn't even make jacks. Return it of toss it IMHO.
Jacks can be dangerous if they fail. If it were a good brand I would have the cylinder serviced by the company.
Re: Michelin jack won't lift a load [Re: Trav] #4879770 09/26/18 11:30 AM
funflyer Offline
China can copy and produce hard parts pretty well, it's the rubber compounds they have trouble with. I bought a cheap Chinese jack back in the 80s and within the first year it started to fail/leak, not surprising. So, being an aircraft mechanic, I headed over to see my friend in the hydraulics shop. He fixed me up with new o-rings, seals and backups and that jack is still going strong today. Now, do I trust my life with it? Heck no! I never crawl under a vehicle without jack stands in place and the weight relieved from the jack.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
