Slick 50
by rrretiree7 - 11/12/19 01:19 AM
Need Spring Compressor OTC 6494?
by Wolf359 - 11/12/19 12:48 AM
2009 Accord V6 terrible MPG
by JEL01 - 11/11/19 11:04 PM
How to fix exhaust broken at the flange?
by slacktide_bitog - 11/11/19 10:53 PM
Bugs Bunny
by red7404 - 11/11/19 10:40 PM
Keep with Conventional for 2001 Buick?
by JGmazda - 11/11/19 09:44 PM
Air Compressor Stalling
by spasm3 - 11/11/19 08:57 PM
1977 2-stroke moped ESSO 2-T 18:1?
by N8conn - 11/11/19 08:50 PM
*NEW* DELO 600 ADF
by SavagePatch - 11/11/19 07:48 PM
2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30
by Colt45ws - 11/11/19 07:24 PM
Amsoil Upper Cylinder Lubricant
by Donald - 11/11/19 06:41 PM
Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
Scuder, Jasonrmcc, Capacc, allofoil, Chizzle
69837 Registered Users
17 registered members (Char Baby, GMBoy, Black_Thunder, KneeGrinder, 4 invisible), 675 guests, and 20 spiders.
Topics297,296
Posts5,112,474
Members69,837
Most Online3,589
Nov 2nd, 2019
Toyota Pink + RMI-25 10 years #4876317 09/22/18 09:27 PM
B
burla Offline OP
B
Right is 10 years on toyota super long life coolant plus RMI-25, as you see the rmi25 turns it orange (yellow plus red or pink = orange). The middle was second flush, I was pretty happy with how it looked, and I have no doubt a third flush isn't necessary, mind you what is in there now was fresh put back when the coolant looked like the middle jug. So even better then what is in the reddish jug. I always put RMI-25 in towards the end of my coolant interval, I've had great luck with it in the past take out slime in radiator and put's it into the overflow where it gets stuck. Many other benefits as well like guards against electrolysis. Probably didn't need it this run, this vehicle was bought new in 2008, but as vehicles get older I think rmi25f is worth it.
[Linked Image]
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876319 09/22/18 09:30 PM
B
burla Offline OP
B
That RMI-25 was in there for last 3 of the ten years.
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876438 09/23/18 05:43 AM
Snagglefoot Online Content
Online Content
On the topic of Toyota coolants here are a couple of knockoff’s both in the 50/50 and concentrated types.
If you want the job done right......do it yourself.
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876590 09/23/18 09:35 AM
StevieC Offline
This isn't aimed at the OP, just a comment in general. If these long life coolants are rated for 10 year and X-mileage why don't folks do a spill/fill of the radiator in 1/2 that time to always keep clean coolant in the system and eliminate the need for flushing or worrying about things like freeze point, boiling point or electrolysis? Plus the added benefit of alway keeping the additives in the coolants that prevent scale at high levels.
It would seem to me it would be greater expense in both time and fluid to have to do 3 flush/fills instead of just changing out approximately 1/2 the coolant at 1/2 it's life expectancy so that the system is always full of fresh coolant.
I have always done this and never experienced the need for flushing, or problems like heater core issues etc.
Just a thought, not questioning what everyone does and certainly no aimed at the OP.
'18 Caravan - 45k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876661 09/23/18 10:36 AM
B
burla Offline OP
B
No worries at all, I don't mind having my strategies questioned. If you stay on top of it as you say that would be perfect. However, I have a ton of things in my life that get in the way of me doing maintenance of my vehicles. An example is for the last two months I have chain sawed at least 1/2 of my days and I'm not even at the half way point of what it takes yearly to keep the branches down on my property. So when I get to the end life of a coolant, I opt for rmi-25 based on the experience I had with it removing sludge. I like your idea, but still prefer doing a double flush. It isn't that much work and coolant isn't that expensive, but boy if something goes wrong with the cooling system it will be. My hopes that I can find the time to do a double flush 4 years from now.
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876664 09/23/18 10:39 AM
B
burla Offline OP
B
If you can find the engine block bolts top and bottom, then why not just do the full flush. Also, my second flush was hot just to see how it was, no problem at all since I can do everything from the top of the engine. Flush with t stat still open, get more out.
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876745 09/23/18 11:57 AM
StevieC Offline
If running the full 10 years I would either do a flush or a series of spill/fills. But what I was getting at is if you have the time then run the coolant to 1/2 it's life span and drain 1/2 the coolant, it's easy, no fuss, no mess and has always worked well in my experiences to not require flushes ever because the fluid is always clean in the system and protecting well.
The main thing is you are doing it before it's really ugly, or doing it at all! grin2
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876769 09/23/18 12:26 PM
B
burla Offline OP
B
I guess most people wouldn't choose to do a flush on a new car 1/2 way through the manual's interval, but then again maybe we should. Not a bad idea.
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4876927 09/23/18 03:39 PM
StevieC Offline
Not a flush, just a drain the radiator and refill with new pre-mix.
Re: Toyota Pink + RMI-25 10 years [Re: Snagglefoot] #4876942 09/23/18 03:51 PM
G
Garak Offline
G
I can't speak for Toyota, but even the Infiniti dealer beats the Canadian Tire price. wink
Plain, simple Garak.
Re: Toyota Pink + RMI-25 10 years [Re: StevieC] #4877575 09/24/18 09:26 AM
circuitsmith Offline
That's what I did with my '06 Matrix. A 15 minute job every 5 years. Zerex Asian the second time.
The 5 year old coolant coming out looked as clean as the new.
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: Toyota Pink + RMI-25 10 years [Re: Garak] #4877984 09/24/18 04:54 PM
N
nthach Offline
N
Some Toyota dealers can be generous. I get the bro hookup at the local dealership.
I'd trust the Zerex stuff. Dunno if the Recochem/OEM stuff is a legit pHOAT or simply Dex-Cool dyed pink or red like Prestone.
Re: Toyota Pink + RMI-25 10 years [Re: nthach] #4878095 09/24/18 06:39 PM
G
Garak Offline
G
Finding the Asian Zerex is hit or miss at times here, plus, the Japanese OEMs here tend to sell concentrate, rather than just 50/50, which can be quite handy here.
Re: Toyota Pink + RMI-25 10 years [Re: StevieC] #4921443 11/11/18 07:24 PM
O
Onetor Offline
O
That is a good idea StevieC,
Ty
N = R* x fp x ne x fl x fi x fc x L
Re: Toyota Pink + RMI-25 10 years [Re: burla] #4922100 11/12/18 01:21 PM
M
mctmatt Offline
M
To the OP as I too am a fan of RMI-25 as I started using in last year in some of our vehicles and from my experience at least with a 96 Ford Taurus I did see much cooler temperature readings than what I was previously seeing before it was added. I now add it after I do a radiator flush when refilling with radiator fluid.
