Northrop B-2 Spirit - First Cockpit Video
by john_pifer - 08/23/19 10:36 AM
ADBV Design - MANN Filter
by LeoStrop - 08/23/19 10:25 AM
"MYSTERY Oil" - 320 ppm Zinc
by Linctex - 08/23/19 10:20 AM
Thoughts on Time v Mileage
by BISCUT - 08/23/19 10:04 AM
Shocks / Struts
by WyrTwister - 08/23/19 08:04 AM
Stihl HT 50 CE Pole Pruner
by ssamaroo01 - 08/23/19 08:01 AM
LQ4/LQ9 direct swap for LS1?
by cwilliamsws6 - 08/23/19 08:00 AM
Fearing the RockAuto worst
by Kira - 08/23/19 07:40 AM
Minimum octane for 2016 2.0 ecoboost?
by Corollaman - 08/23/19 07:06 AM
Weedwacker advice
by supton - 08/23/19 07:05 AM
Temps pre & post diff cover change
by kehyler - 08/23/19 06:51 AM
DIY: Mazda 2.5L Skyactiv Water Pump
by The Critic - 08/23/19 06:03 AM
vavoline syncpower 4T
by bonjo - 08/23/19 03:24 AM
Great Price but...
by Marco620 - 08/23/19 02:02 AM
CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
lubetech82, Lockguard, PTL, vdubw, NJ01MGM
69036 Registered Users
101 registered members (1978elcamino, 01rangerxl, 94astro, 14Accent, 2010Civic, 53' Stude, 12 invisible), 2,060 guests, and 27 spiders.
Topics293,679
Posts5,044,871
Members69,036
Most Online3,532
Jul 30th, 2019
Michelin jack won't lift a load #4876379 09/23/18 01:32 AM
1
10WSmuckers Offline OP
1
Hi all. I have a 3 1/2 ton Michelin floor jack that has the quick lift feature but it has now rendered itself useless. It will raise and lower itself without any weight on it but anything like a car is out of the question. It will just stay under the car and squeak loudly with every pump. There are 3 screws behind the pump cylinder and I don't want to risk adding more air into what I suspect isn't the oil fill plug. In fact they say "DO NOT ADJUST" around these 3 plugs and this isn't something I want to mess up completely. How can I bleed the air out thoroughly?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876420 09/23/18 05:21 AM
Ducked Offline
It IS messed up completely. It doesn't work.
How do you imagine you are going to make that worse?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876435 09/23/18 06:35 AM
W
wdn Offline
W
Good reason why top brands should never license their brand name to put on other random stuff that is not made by them. I hope my Kubota shop vac holds up.
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876453 09/23/18 07:21 AM
E
eljefino Offline
E
Take it all apart and look for shot o-rings.
Re: Michelin jack won't lift a load [Re: eljefino] #4876469 09/23/18 07:52 AM
spasm3 Offline
You have nothing to lose by doing this. Its shot either way.
I'd watch this and give it a try.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876503 09/23/18 08:19 AM
J
jkasch Offline
J
If you haven't yet, try this first.
Bleeding
1. Remove the Cover Plate.
2. Loosen the Fill Screw.
3. Turn the Handle counterclockwise to open the Release Valve.
4. Pump the Handle up and down quickly several times to purge air from the system.
5. Check oil level and add as explained below, if needed.
6. Tighten the Fill Screw and replace the Cover Plate.
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876565 09/23/18 09:59 AM
CT8 Offline
How old is the jack?
Re: Michelin jack won't lift a load [Re: 10WSmuckers] #4876649 09/23/18 11:26 AM
T
Trav Offline
T
I would even try to fix it, its a cheap Chinese jack with a brand name from a company that doesn't even make jacks. Return it of toss it IMHO.
Jacks can be dangerous if they fail. If it were a good brand I would have the cylinder serviced by the company.
Re: Michelin jack won't lift a load [Re: Trav] #4879770 09/26/18 11:30 AM
funflyer Offline
China can copy and produce hard parts pretty well, it's the rubber compounds they have trouble with. I bought a cheap Chinese jack back in the 80s and within the first year it started to fail/leak, not surprising. So, being an aircraft mechanic, I headed over to see my friend in the hydraulics shop. He fixed me up with new o-rings, seals and backups and that jack is still going strong today. Now, do I trust my life with it? Heck no! I never crawl under a vehicle without jack stands in place and the weight relieved from the jack.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
