MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
Oil Life Monitor
by rrretiree7 - 07/06/20 06:57 PM
94 F 150 Engine control module replaced
by Electromotive - 07/06/20 06:43 PM
OIL UDDER Q+A
by OIL_UDDER - 07/06/20 05:46 PM
Devil's Lake State Park near Baraboo, WI
by wwillson - 07/06/20 05:43 PM
New vehicle bug bit me again
by JTK - 07/06/20 04:56 PM
2012 Ram 2500 Delvac 15W40 3,000 miles
by tnt_motorsports - 07/06/20 04:43 PM
Cooling System Pressure Tester
by 92saturnsl2 - 07/06/20 04:39 PM
GMC YUKON HYBRID P-0300 code
by 53' Stude - 07/06/20 04:18 PM
Is it worth its weight in cast iron?
by spavel6 - 07/06/20 03:42 PM
Hyundai O.E.M. 28113-H8100 replacement
by odie - 07/06/20 03:22 PM
Valvoline SynPower Power Steering Fluid
by Cheezit - 07/06/20 03:17 PM
Shell Rotella Gas Truck or Pennzoil?
by DCMotorsports - 07/06/20 02:49 PM
Interesting domino game
by 53' Stude - 07/06/20 02:49 PM
Grinding brakes when hot
by mclasser - 07/06/20 02:41 PM
Nylon spacers
by VeeDubb - 07/06/20 02:37 PM
ssoH, Sumpter_al, Jeffham87, chknkatsu, Colt_38
71866 Registered Users
115 registered members (2009Edge, 2015_PSD, Alaskanmont, 2010Civic, AndyB, 928, 11 invisible), 2,024 guests, and 34 spiders.
Topics307,515
Posts5,312,438
Members71,866
Should have changed it? #4876308 09/22/18 10:14 PM
P
parshisa Offline OP
P
Changed the oil in my pilot today at 3700mi (MM was at 20%) but left the filter on( Honda A01). Was that a right move it should have been changed oout as well? I feel like i did ok although would like to hear y’alls opinion
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: Should have changed it? [Re: parshisa] #4876310 09/22/18 10:18 PM
T
TheLawnRanger Offline
T
According to what oil you were using, you possibly could have skipped both.
2011 Impala
2012 Colorado
2018 Buick Encore
Oil: 5w30 synthetic
Re: Should have changed it? [Re: TheLawnRanger] #4876313 09/22/18 10:20 PM
P
parshisa Offline OP
P
I had to in order to be compliant with warranty requirements
Re: Should have changed it? [Re: parshisa] #4876323 09/22/18 10:32 PM
Z
ZeeOSix Offline
Z
Honda usually says to change the filter every other OCI - check the maintenance schedule.
Re: Should have changed it? [Re: ZeeOSix] #4876325 09/22/18 10:40 PM
SnowDrifter Offline
I actually didn't believe you until I looked it up
That's rather curious
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Should have changed it? [Re: parshisa] #4876326 09/22/18 10:40 PM
dave1251 Offline
According to your orginal post this was not the case.
don't use.
Re: Should have changed it? [Re: dave1251] #4876328 09/22/18 10:43 PM
P
parshisa Offline OP
P
20% or 15% on MM doesn’t make that much of a difference. Car has been up anyways so i figured why not. Free oil went in. Filter stays on. How did i do?
Re: Should have changed it? [Re: parshisa] #4876331 09/22/18 10:51 PM
T
T
I would have changed it unless the filter is rated to go a lot longer. I don't know a lot about the reputation of your filter but you should be ok if changing every 3700 miles or so.
2011 Impala
2012 Colorado
2018 Buick Encore
Oil: 5w30 synthetic
Re: Should have changed it? [Re: TheLawnRanger] #4876340 09/22/18 11:06 PM
P
parshisa Offline OP
P
Given the fact that Honda recommends chaning filter every other OCI, my Civic would have to have filter on for around 20K ( MM on it goes on at 10K). I guess they believe it lasts
Re: Should have changed it? [Re: parshisa] #4876347 09/22/18 11:13 PM
Snagglefoot Online Content
Online Content
I’m trying to get 20,000 miles on a Fram Ultra using multiple OCI’s.
If you want the job done right......do it yourself.
Re: Should have changed it? [Re: SnowDrifter] #4876361 09/22/18 11:44 PM
W
Wolf359 Offline
W
Not really. If people read the manual, that's actually been standard for lots of cars.
Re: Should have changed it? [Re: Wolf359] #4876371 09/23/18 01:02 AM
SnowDrifter Offline
Curious for me. Every car I've messed with has had it spec'd oil and filter.
Saying "if people read the manual" is somewhat self defeating as most wouldn't have access to manuals of new cars, let alone memorize them and stay up to date.
2005 Tahoe - 140k
Re: Should have changed it? [Re: parshisa] #4876426 09/23/18 06:10 AM
P
PWMDMD Offline
P
I do question these MMs. You’re at 3700 miles on the oil and you’re at 20%. On my 2018 Pilot I currently have 4800 miles on the oil and I just hit 50%. It’s been a hot summer here, I’m mostly city driving, give it the beans all the time and do a fair amount of idling. Hmmm....
Current: 2020 Toyota Tundra Platinum (PP 0W-20 and Toyota OEM Filter) and 2019 Lexus RX 350 (PP 0W-20 and Toyota OEM Filter)
Re: Should have changed it? [Re: Wolf359] #4876427 09/23/18 06:13 AM
P
PWMDMD Offline
P
I can’t remember a single car I’ve owned that didn’t state the filter should be changed every other OC.
Re: Should have changed it? [Re: parshisa] #4876447 09/23/18 07:11 AM
Online Content
And every other OC is just a nominal suggestion. With a quality filter that can be 3x or 4x.
