When I do these I get all the cables and most of the terminal lugs from AC/DC supply, all USA made wire and terminals and use tinned marine battery cable and lugs.
In the salt belt terminal corrosion is a real issue,I had a Ford F150 starter cable rot right off.
Remy has the 45 and 90 degree for the starters and for the MKIV military terminals are the best bet as you need 2 positive cables, one for the starter and the other for the fuse box on top of the battery.
These are real easy to make, I did use solder slugs but now crimp and solder. I buy (or cut my own) lugs with a peep hole in the front of the lug, hex crimp it then put a couple of drops of kessler rosin flux down the hole, heat it with a propane torch and put some rosin solder in the peep hole. This give a nice soldered joint in the front of the lug without wicking all the way up into the cable making it brittle then good heat shrink tubing.
Alternator to starter or fuse box AWG 4, battery + to starter 1/0, fuse box to battery + AWG 2, battery neg to engine ground 1/0, engine to chassis 1/0 and then a few extras.
I add battery neg to body 1/0, front alternator bracket to front engine mount 1" tinned copper braided strap, upper plenum to firewall 1/2" tinned copper braided strap and finally battery fuse box to interior relay panel AWG 4.
This seems to cure most of not all electrical gremlins in these cars, it takes about 3 hrs to do right, the key to lifelong performance of the cable is to use tinned cable and lugs if you live in high salt areas.
https://www.acdcwireandsupply.com/
https://www.remybattery.com/cable-c...s-lugs-and-terminals/lug-connectors.html
