Just doing some vehicle washing today I noticed a black greasy like substance on my garden hose.
Not knowing what it was (different consistency than Krown rust proofing) I noticed a decent size spot on my driveway.
My truck had been parked in that spot all day. I went to where the truck was now parked and sure enough, right under the front control arm area I noticed another small puddle and wiping the driveway again, it was the same greasy like substance.
I did notice what looked like an amber colored drip hanging from the control arm above where the spot was on the driveway.
Could this be brake fluid leaking/dripping from somewhere or possibly gear lube?
My gut tells me brake fluid as it seems to be lifting the driveway sealer and I am not sure gear lube would do that?
Any clues as to where this leak might be coming from? My brake reservoir looks quite full still but I believe the leak just started within a day or 2.
My truck has electric power steering so there is no way it could be power steering fluid.
Thoughts?
Edit: I forgot to add, it is/was getting too dark out to pull the front wheel to have a closer look but will tomorrow in the daylight.
Thoughts?
