Originally Posted by maxdustington
Never seen a cord get damaged ever, and I have used all sorts of high amp tools with many different gauge cords sometimes plugged into each other. I've been told that it can make the motor work harder eg: I've been told to not run an air compressor off an extension cord. But I've done that with no ill effects.
That image is a joke, go to any jobsite and try to find a twist lock. Most people are running their chop/table/skillsaws on thin cheap extension cords and they dim the lights just the same as the thick ones.
Maybe a high draw light would heat the cord up, but power tools are too intermittent.
The problem isn't the cord itself overheating, odds are whatever you're trying to run won't be able to draw enough power well before that point. I've had issues running my 15-amp compressor at the end of a long extension cord (motor would just hum until it tripped the breaker, never started), table saw (bogged down and tripped the breaker cutting stuff it had no problem with plugged into the wall), and even my 9-amp chainsaw seemed noticeably weaker at the end of a long, small cord. I now use a couple of 100' 12 gauge cords and even plugged into each other, I have no issues.
And since this is an oil site, I'll note that my compressor starts easier on Mobil 1 AFE 0w-20 than it did on China Freight 30 weight.
