My current car (see below) subsisted on the manufacturer's recommended 0W-20 (mostly TGMO, plus one change of RK and one of PP) until switched to PP 5W-20 for the past 2½ oil intervals. I made that change not out of fear 0W-20 is "too thin" for conditions, but in hope the lower volatility and lower VII loading of 5W-20 might reduce the risk of ring coking. Conditions are generally benign, other than the frequent hot starts, and some long hills to climb. No hint of any engine issue, so far.
My Mazda (also below) went over 600k miles on mostly 10W-40 with no signs of engine wear (although it had other engine issues!).
