Originally Posted by CR94
Of course, if one holds the dipstick vertically with handle at the top, the upper portion of oil on it will flow down to make the lower part thicker. .
I always read my dipstick at horizontal (flat) a second or two after pulling it. ...
I do that too, which minimizes the normal sagging down effect, but it doesn't prevent the top of the oil seeming to peel clean off the metal immediately.
I've seen it suggested on here that synthetic oil (whatever that is) drains off engine surfaces quicker, though of course I've also seen it denied.
Maybe you should get a bottle of old school stuff and compare.
