Retirement advice
by dja4260. 06/18/19 02:10 PM
Oil for DI
by Coastie05. 06/18/19 01:57 PM
Edge or Edge EP for friends Venza
by 53' Stude. 06/18/19 01:11 PM
Found a Premium Blue Restore VOA
by SubyRoo. 06/18/19 12:44 PM
Semi-Syn
by nicholas. 06/18/19 11:30 AM
Particle Count (PC) testing of used oil
by Talent_Keyhole. 06/18/19 11:25 AM
Added individually, coolant & water won't mix?
by Ed_Flecko. 06/18/19 11:15 AM
02 silverado diff fluid....
by Jcountry. 06/18/19 11:06 AM
Arteries
by CourierDriver. 06/18/19 10:17 AM
Remember the Officers
by CourierDriver. 06/18/19 10:02 AM
New TV
by WyrTwister. 06/18/19 08:45 AM
Best cheap filter?
by jayjr1105. 06/18/19 08:37 AM
BB Pistol- The Peacemaker
by CourierDriver. 06/18/19 06:33 AM
Zoro.com 20% off sale
by SubieRubyRoo. 06/18/19 06:24 AM
Why such a low temp thermostat?
by Chris142. 06/17/19 11:21 PM
Abnormal Wear on Tire?
by A_User55555. 06/17/19 11:17 PM
Jag F Type
by Snagglefoot. 06/17/19 11:00 PM
Petethedog, RenewableLubeBen, flattire101, Score294, PublicStellar
68426 Registered Users
100 registered members (Alfred_B, 928, 53' Stude, aquariuscsm, 92saturnsl2, 10 invisible), 2,142 guests, and 32 spiders.
Topics290,619
Posts4,989,643
Members68,426
Most Online2,967
Mar 10th, 2019
Need Help with Double D Knock Out Punch #4874931
09/21/18 03:41 PM
09/21/18 03:41 PM
CA
user52165 Online content OP
user52165  Online Content OP
CA
OK - that got your attention, but it's not that.
Need a Greenlee double "D" knockout punch. Or equivalent.
3/4" x 2/3" - .75 x .67
It used to be a common size for electronics chassis - used to be............... that is 40+ years ago.
Some upward tolerance is OK.
Doesn't seem to be made now.
Ideas? Thanks guys.
Re: Need Help with Double D Knock Out Punch [Re: user52165] #4874944
09/21/18 03:51 PM
09/21/18 03:51 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Aren’t there a bunch of them for sale on eBay?
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Need Help with Double D Knock Out Punch [Re: user52165] #4874950
09/21/18 03:53 PM
09/21/18 03:53 PM
New England
gathermewool Online content
gathermewool  Online Content
New England
Did you check the etherwebs?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Magnatec 5W-20 + FU filter (47,300 miles)
Re: Need Help with Double D Knock Out Punch [Re: kschachn] #4875080
09/21/18 06:25 PM
09/21/18 06:25 PM
CA
CA
Not that size.
Re: Need Help with Double D Knock Out Punch [Re: user52165] #4875440
09/21/18 10:53 PM
09/21/18 10:53 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
Unless you can find a Chinese knockoff or a used one on eBay you don’t have much options other than greenlee. There are a few meant for locks out there. Is it a lock application or electrical? If it is electrical you can find a good selection of 22mm or 30mm round devices.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Need Help with Double D Knock Out Punch [Re: user52165] #4875689
09/22/18 09:05 AM
09/22/18 09:05 AM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
In the past, I needed to make some D shaped holes for bulkhead connectors and I didn't have a D punch so I used a punch that was close and small and then filed one side flat and went at the rest with a round file to make up the diameter. Worked great but took some time. No where near as fast as a punch.
