diesel injector cleaning/service
by DriveHard - 08/20/19 12:02 PM
Time for an oil change???
by RoadDukie - 08/20/19 12:00 PM
Pennzoil High Mileage conventional moly content.
by aquariuscsm - 08/20/19 11:59 AM
onboard auto tool kit
by phillyFX4 - 08/20/19 11:24 AM
No way to follow a thread?
by paulri - 08/20/19 10:59 AM
Schumacher Instant Power&Air
by Char Baby - 08/20/19 10:25 AM
PolishAngel - Engine
by buster - 08/20/19 08:59 AM
Pennzoil Platinum HM 5w20 15 Jeep GC 3.6L
by 1nighttrain - 08/20/19 08:42 AM
Any Midweight Moto Guzzi Fans Here?
by Silverado12 - 08/20/19 08:31 AM
Central AC drain pump fail, flood
by LeakySeals - 08/20/19 06:38 AM
WiFi “bridge” to outbuilding
by dlundblad - 08/20/19 05:00 AM
Rental review : 2019 Dodge Charger
by FirstNissan - 08/20/19 12:14 AM
Truck diesel oil in Lawn mower (SAE30)
by Polyalphaolefin - 08/19/19 11:18 PM
Pinstripes Not Popular on Pickup Trucks?
by LoneRanger - 08/19/19 10:04 PM
More choices
by KeithS_NW_Ohio - 08/19/19 09:43 PM
INEOS to Surpass EXOM in PAO production.
by MolaKule - 08/19/19 09:17 PM
Need a miter saw
by JLawrence08648 - 08/19/19 09:01 PM
Using a 7.1 receiver with only 2 speakers
by Papa Bear - 08/19/19 08:44 PM
HD Sportster 5000 mi Red line PS 20w-50
by shanneba - 08/19/19 07:17 PM
ticojr02, Timdetails, rangeseven, GNH82, BigMike61
69008 Registered Users
98 registered members (53' Stude, AlienBug, akela, 1978elcamino, 2010Civic, 01rangerxl, 10 invisible), 2,319 guests, and 27 spiders.
Topics293,560
Posts5,042,386
Members69,008
Most Online3,532
Jul 30th, 2019
Page 3 of 4 1 2 3 4
Re: Liqui Moly Oil Additive [Re: OilUzer] #4881110 09/27/18 01:14 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by OilUzer
Do you guys know what is in Rislone oil treatment/additive?
STP oil treatment says it has zddp on the bottle ... but Rislone doesn't specify and I wonder if it has moly or not. It is very popular with good reviews. Just curious what's in it crzy
I do like Red Line numbers ... Very solid oil!
It is a 20 grade:
Rislone Engine Treatment from quart bottle (32 oz.) version.
Physical Tests:
Viscosity (cSt 40C) 43.0
Viscosity (cSt 100C) 8.0
Additives (ppm):
Magnesium (Mg) 3
Calcium (Ca) 1935
Phosphorus (P) 422
Zinc (Zn) 503
Boron (B) 8
TMP Ester ~ 11% by weight.
The amount of ZDDP is at a level to supplant the ZDDP when this stuff is added.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: Liqui Moly Oil Additive [Re: racin4ds] #4884021 09/30/18 06:41 PM
dave1251 Offline
Originally Posted by racin4ds
Get that water for oil out of that Hemi and put a good 5-10W30 in it and your tick will disappear... especially living in GA, cold starts aren't really a concern.
How would a oil when at startup is very thick thicker than a 30 grade at operating tempature help? It makes no sense a very thick oil there is a tick and when it thins out the tick goes away.
don't use.
Re: Liqui Moly Oil Additive [Re: MolaKule] #4891538 10/09/18 02:36 AM
O
OilUzer Offline
O
It is a 20 grade:
Physical Tests:
Additives (ppm):
Magnesium (Mg) 3
Calcium (Ca) 1935
Phosphorus (P) 422
Zinc (Zn) 503
Boron (B) 8
Thanks!
Re: Liqui Moly Oil Additive [Re: dawgn86] #4913251 11/02/18 10:06 PM
O
Onetor Offline
O
Originally Posted by dawgn86
What positives / negatives can you tell me about this engine oil additive? Liqui Moly MOS2 Anti-friction engine treatment.
have a 2012 Jeep Cherokee with the 5.7 hemi engine that has a light tick on startup. The can says it is 300 ml; how much would be needed on a 7 quart oil change?
Thanks
Redline will cure that tick. If it's the lifters..
N = R* x fp x ne x fl x fi x fc x L
Re: Liqui Moly Oil Additive [Re: dawgn86] #4916023 11/05/18 09:20 PM
J
jacobsond Offline
J
Are you sure its not an exhaust manifold leak. Kind of common on the dodge. Sounds just like a lifter (lash adjuster) tic I am told. How about a mechanic stethoscope on the valve covers to make sure its a lifter. I have a dodge 4.7. I have the dreaded tic.Lifters sound the same warm and cold with the stethoscope. I used the output of a shop vac to pressurize my exhaust and confirmed an exhaust manifold gasket failure. I have yet to replace the gaskets. With winter coming up here in ND might wait until spring. If something goes wrong with those rusty as heck studs I don't want to have to drive the Geo Tracker ragtop while I repair broken studs. Most Dodge guys will tell you if the tick goes away after a few min don't worry about it.
Re: Liqui Moly Oil Additive [Re: Linctex] #4917188 11/06/18 10:33 PM
CT8 Offline
Originally Posted by Linctex
Originally Posted by 1JZ_E46
LM MoS2 will settle out of suspension as it’s not in a true liquid soluble form. I looked into it but decided against it after hearing advice from people far smarter and more knowledgeable on the subject.
I have heard this as well.
Where does it go to?!?!?
Trapped in all the little pockets where sludge usually forms?
Or does it get stuck in the pleats of the oil filter and stay there?
The nooks and crannies ! horse
Re: Liqui Moly Oil Additive [Re: dawgn86] #4917527 11/07/18 12:03 PM
Diesel12 Offline
Look into TUFOIL. In the Guinness book of world records for most efficient lubricant. Has 4.8 out of 5 stars on amazon with 138 reviews. NEVER been sued by the FTC. Its awesome stuff in my opinion, one of the best additives i have came across.
Amazon- https://www.amazon.com/Tufoil-Engin...541610050&sr=8-1&keywords=tufoil
Tufoil website- https://www.fluoramics.com/tufoil/tufoil-for-engines/
1998 Dodge Neon-Rebuilt 2.4L-Schaeffer 10w-30
2014 Dodge Durango 3.6, 66K- Schaeffer 10w-30
2002 Ram 2500 Cummins 125K- Schaeffer 5w-40
2008 Dodge Avenger 232K Schaeffer 10w-30
Re: Liqui Moly Oil Additive [Re: Diesel12] #4917646 11/07/18 02:22 PM
K
kschachn Online Content
Online Content
K
PTFE has no place in motor oil and DuPont specifically disavowed and warned against any use of their product for that application.
What specific test results posted to the Tufoil website lend credence to their vague claims? I asked you that the last time when you promoted Tufoil but you didn't respond.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: Liqui Moly Oil Additive [Re: dawgn86] #4918155 11/08/18 06:17 AM
Diesel12 Offline
I just go by real world reviews from people that have actually used it including myself. Actually just 3 days ago i added some to my fathers 03 Durango 4.7 with 220K miles that had some nice lifter noise. After 5 min the noise was gone and his truck ran smoother than it ever has. I dont think ive ever read a bad review on Tufoil. I do my own research, experiment for myself and make my own decisions/observations. I like to think for myself not let propaganda persuade my findings.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4918742 11/08/18 07:23 PM
DirtyOilGuy Offline
so the liqui moly MOS2 isn't oil soluble. i could've sworn i read about another brand that was soluble. am i mistaken? any help?
Re: Liqui Moly Oil Additive [Re: dawgn86] #4919102 11/09/18 11:06 AM
M
milwiron Offline
M
So... before anyone rips me a new one I totally admit my results here are strictly anecdotal with no science involved.
I drive a 2005 Dodge Ram 5.7 Hemi in good shape with 208,000 miles on it. The engine burns no oil and has no unusual sounds coming out of it. I'm retired and drive the same routine week after week, local driving, some highway driving to big box stores like Menards and Home Depot and one or two trips a month to visit our daughter and her family 90 miles away. I want to get another year out of the truck before buying a new one.
For a couple of years I averaged 15.6 mpg, that number virtually never changed. A little over three months ago I added a can of regular size (not truck) Liqui Moly to the engine and reset the display. Within a week the mpg average sat at 16.4 and after three months it still sits at 16.4. I don't believe my driving habits have changed, I'm no more easy on the accelerator than before and I still cringe every time I look at the gas gauge.
Something is giving me better mileage, sure it could be something else but I'll probably add another can of Liqui Moly after the next oil change just in case it does make the old truck happier. Your results may vary.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4920315 11/10/18 05:18 PM
R
RayCJ Offline
R
LiquiMoly 2009, and other forms of molybdenum have been used in manual lathe and mill gearboxes for a long time. 10, maybe 15 years ago, I had a lathe that had a nasty habit of superimposing gear vibration marks onto the workpiece being cut. This was due to the pressure angle on the gear teeth of this particular lathe. Someone suggested using different lube etc and eventually that lead to trying LiquiMoly. It worked. As I recall, the gearbox held about 2.5 gallons of ISO 60 hydraulic oil and I poured one can of LiquiMoly in there. Within 5 minutes, I could hear the change in how the machine ran. Much quieter... The superimposed gear marks went away too.
Of course, there's a big difference between a lathe gearbox and a gasoline IC engine... Huge difference! But anyhow, I did some experiments with LM 2009 and will probably try it in one of my cars at the next OC. In machine shops, I've used various forms of Moly lubes and they worked well. There are places where Moly should be avoided but, off the top of my head, don't see a problem with modern gas IC engine.
They recommend roughly 300 ml / 5qts oil and that comes out to a 16:1 ratio.
Here it is mixed with M1 (16:1 exactly) then warmed-up in a hot water bath of 180F then, mixed thoroughly with the syringe tip. Next, it sat in a deep freezer at -10 F for 3 days. Upon taking it out, it was all perfectly held in suspension with absolutely no evidence of settling out or caking on the bottom. When warmed back up to 180, it looked no different than the first time I mixed it. No settling whatsoever.
5 family cars... What the heck, I'll give it a shot. Yes, I've seen the videos of people putting this in their lawn mower etc... Fortunately, my car is not powered by a lawnmower engine.
Ray
IMG_20181110_085229.jpgIMG_20181110_085522.jpgIMG_20181110_090307.jpgIMG_20181110_162358.jpg
Re: Liqui Moly Oil Additive [Re: dawgn86] #4921837 11/12/18 09:41 AM
R
RayCJ Offline
R
Two or three more days sitting at -10F in the deep freezer. The first picture was taken right out of the freezer, un-shaken or stirred and before condensation had a chance to frost-up the beaker. Surprisingly, even at that cold temperature, the oil is surprisingly fluid. -Not at all as viscous as I would imagine and probably less so than maple syrup at warm household room temperature. The moly still looks very suspended in the solution.
In the second picture, the beaker has warmed-up to garage/shop temperature has not been shaken or stirred. It's about 52F according to the wall thermometer and the oil is downright "liquidy". When holding the beaker edge-wise and looking through the oil, the moly seems evenly dispersed through the volume of fluid. If I were to warm this up, it could be poured out and basically leave the beaker clean but with a film of oil with a light grey tint. There are absolutely no signs of moly caked, crusted or clumped and stuck to the bottom of the beaker.
I wonder why some motor oils have only 20-30ppm and some have 500 to 600 ppm. From a chemical perspective, it's fairly harmless. It's everywhere in the ground, soil etc.
Ray
Re: Liqui Moly Oil Additive [Re: dawgn86] #4922010 11/12/18 12:29 PM
PimTac Offline
“I wonder why some motor oils have only 20-30ppm and some have 500 to 600 ppm. From a chemical perspective, it's fairly harmless. It's everywhere in the ground, soil etc.“
Different forms of moly just like there are different forms of any mineral.
Trinuclear Moly needs less to accomplish the same effect as the moly disulfide.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Liqui Moly Oil Additive [Re: RayCJ] #4923239 11/13/18 04:20 PM
M
milwiron Offline
M
Originally Posted by RayCJ
LiquiMoly 2009, and other forms of molybdenum have been used in manual lathe and mill gearboxes for a long time. 10, maybe 15 years ago, I had a lathe that had a nasty habit of superimposing gear vibration marks onto the workpiece being cut. This was due to the pressure angle on the gear teeth of this particular lathe. Someone suggested using different lube etc and eventually that lead to trying LiquiMoly. It worked. As I recall, the gearbox held about 2.5 gallons of ISO 60 hydraulic oil and I poured one can of LiquiMoly in there. Within 5 minutes, I could hear the change in how the machine ran. Much quieter... The superimposed gear marks went away too...
Ray
Funny you mention this. In my early days in the machine trades I occasionally ran a gear head lathe with worn gears. Any time I tried to take a light finish cut it chopped a beautiful herringbone pattern in to the surface of whatever I was cutting. It was a cool finish... but not what I was after.
Thanks for your tests. I have to wonder how little cans of Liqui Moly travel for months from Germany and then sit on a retailer's shelf possibly for more months with little or no settling. Yet we have to worry about it turning to solidified gunk in the bottom of oil pans after a few weeks of engine inactivity.
Page 3 of 4 1 2 3 4
