Drained and filled with Amsoil ATF.
Make/Model: Jeep Rock-Trac (Rubicon)
Vehicle: 2012 Jeep Wrangler Unlimited
Code
OIL Factory
MILES IN USE 64,056
MILES ON UNIT 64,056
SAMPLE TAKEN 8/19/18
MAKE UP OIL 0
ALUMINUM 16
CHROMIUM 0
IRON 190
COPPER 74
LEAD 0
TIN 2
MOLYBDENUM 0
NICKEL 1
MANGANESE 58
SILVER 0
TITANIUM 0
POTASSIUM 13
BORON 77
SILICON 159
SODIUM 31
CALCIUM 269
MAGNESIUM 4
PHOSPHORUS 302
ZINC 15
BARIUM 5
SUS @ 210 43.9
cSt @ 100 5.38
FLASHPOINT 400
WATER % 0.0
INSOLUBLES % 0.0
TAN 1.2
Blackstone Comments:
Universal averages for a Jeep transfer case give you an idea of typical wear after ~44K miles on the oil. Next to those, there is some extra metal in this sample, but don't be too put off by that. This is the factory fill, so a fair amount of the metal is just lingering material from the initial wear-in period plus normal accumulation over the past 64K miles. We should see a lot of progress with each oil change. No contaminants or oxidized solids were present. TAN is fine at 1.2. Resample in 65K miles.
Code
OIL Factory
MILES IN USE 64,056
MAKE UP OIL 0
ALUMINUM 16
CHROMIUM 0
IRON 190
COPPER 74
LEAD 0
TIN 2
MOLYBDENUM 0
NICKEL 1
MANGANESE 58
SILVER 0
TITANIUM 0
POTASSIUM 13
BORON 77
SILICON 159
SODIUM 31
CALCIUM 269
MAGNESIUM 4
PHOSPHORUS 302
ZINC 15
BARIUM 5
SUS @ 210 43.9
cSt @ 100 5.38
FLASHPOINT 400
WATER % 0.0
INSOLUBLES % 0.0
TAN 1.2
