I'd go with a full saps oil meeting the VW 502 spec such as Castrol Edge 0W40. One can say you don't need a 0WXX in Florida, but I disagree. Lots of people who have old cars do dry starts because the car sits around a lot. Getting the oil to the high friction valve train can only help and that oil has plenty of zinc.
That would be great. I have plenty of this oil on hand
I would use a conventional such as the Rotella 10W30 mentioned above first to see if it leaks oil. Using a modern synthetic oil like Edge 0W40 in a 20+ year old rebuild could spring a few leaks.
I also have plenty of valvoline pbe 5w40 on hand but can't find a voa . I have a uoa in now from my truck
I would also suggest a 10w-30 HDEO like Rotella, Delo XLE, or even Motorcraft HDEO 10w-30. Easy to find, and the extra additives like zinc & phosphorus would be good for this classic engine IMO.
I'd run Rotella.
I would also consider changing to a mild roller and forget about the Zinc issue.
If I ever pull my old Vette 427 apart again, a roller will go in.
I just found a case and a half of Kendal GT1 5w30 in my garage as well. If that is a decent choice I would like to use it up.
So in my possession I have
Vavoline Premium Blue extreme 5w40
Castrol Edge 0w40
Kendal GT1 5w30
PBE is for my 250 so it will get used up either way
Same with the Edge, it's for the F150
The Kendall is not earmarked for anything
I use VR1 20w50 in mine, and it's very not-stock. You'd be fine with the 10w30 if you're not bombing it.
This is one of those engines that's not really going to care much about what you put in it. Pretty much any HDEO at all will keep that engine going forever. Have your pick. I'd avoid the synthetics. Why test 30 year old seals?
