27 registered members (Char Baby, chemman, BLND1, c502cid, ArrestMeRedZ, carlprop, 2 invisible),
894
guests, and 22
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,518
Posts5,137,025
Members70,080
Most Online3,589 Nov 2nd, 2019
Schaeffer's new trans fluid 239s15w-40 super lube
#4658821
02/07/18 08:33 AM
salesrep
OP
OP
Posts: 3,618 |
Schaeffer's 239s15w40 Supreme Super Lube Multi Season "Super Lube Supreme Multi-Season is a high performance, para-synthetic, multi-grade fluid that is specially formulated to provide superior protection and performance in transmissions, torque convertors, final drives, hydraulics and wet brakes as well as machines with combined systems in Caterpillar and other OEM front end loaders, haul trucks, dozers and other heavy duty off-road equipment used in the construction and mining industries that are operated in wide ambient temperature ranges. Super Lube Supreme Multi-Season is specially formulated and engineered to meet and exceed the rigorous specifications of Caterpillar’s TO-4M specification. Super Lube Supreme Multi-Season is also recommended for applications with the following original equipment manufacturer requirements:" Allison C-4 Komatsu Micro-Clutch Vickers 35VQ25"
High quality Specialized Lubricants pay for themselves!
Re: Schaeffer's new trans fluid 239s15w-40 super lube
[Re: salesrep]
#4659062
02/07/18 01:00 PM
MolaKule
Global Moderator
Global Moderator
Posts: 20,623 |
Independent Schaeffer's Oil produces excellent lubricant products.
"Micron Moly® is a liquid soluble type of moly that plated itself to the metal surfaces of the various components, thus forming a solid lubricant film that is able to withstand pressures up to 500,000 lbs. per square inch.'
The only complaint I have is the use of the term, "plating" and it is not a criticism of Scheaffer's but the use of the term in general.
MoDTC, because of it's polarity, "attaches" itself to surfaces and the result is that it forms a set of "sheet-like" interfaces, analogous to a set of plastic coated playing cards.
If the implication is that of electroless plating, also known as chemical or auto-catalytic plating, this is a non-galvanic plating method that involves several simultaneous reactions in an aqueous solution, which occurs without the use of external electrical power. An aqueous solution is a solution in which the solvent is water.
I.e., the term "Plating" IMHO, should not be used, but the term, "attaching" should be used.
"Dr. Larry Fleinhardt: You know that it's considered unsolvable? Charlie Eppes: Well, certainly people who have failed to solve it might think that." From NUMB3RS
[Re: salesrep]
#4870125
09/16/18 11:59 AM
parmm
Posts: 17 |
Anyone have any comments on using this ATF in a late model Honda tranny? The Honda transmissions appear to be fussy about ATF, preferring only a couple types, very fussy about fluid interval and extreme duty light weight towing service. They only recommend the Honda DW1. Very few brands offer the DW1 spec. I am considering the Sheaffer atf in a 2011 Odyssey EX 5sp, and a 2014 CR-V.
[Re: parmm]
#4870914
09/17/18 08:41 AM
MolaKule
Global Moderator
Global Moderator
Posts: 20,623 |
Anyone have any comments on using this ATF in a late model Honda tranny? The Honda transmissions appear to be fussy about ATF, preferring only a couple types, very fussy about fluid interval and extreme duty light weight towing service. They only recommend the Honda DW1. Very few brands offer the DW1 spec. I am considering the Sheaffer atf in a 2011 Odyssey EX 5sp, and a 2014 CR-V. THIS transmission fluid is for Heavy Duty transmissions and with a 100C viscosity of 15 cSt it is NOT suitable for transmissions using ATF's that use 6 (LV ATF) to 7.5 cSt fluids (Dexron III/Mercon) type fluids.
[Re: parmm]
#4872508
09/19/18 06:08 AM
MoparMan12
Posts: 12 |
Schaeffers ALLTRANS supreme is Honda DW-1 Approved.
[Re: MoparMan12]
#4872517
09/19/18 06:25 AM
kschachn
Posts: 12,886 |
Schaeffers ALLTRANS supreme is Honda DW-1 Approved. No it’s not, at least not by Honda.
1994 BMW 530i, 251K 1996 Honda Accord, 280K 1999 Toyota Sienna, 428K 2000 Toyota ECHO, 284K
[Re: salesrep]
#4873270
09/20/18 12:02 AM
wdn
Posts: 603 |
The manufacturer’s statement: “All Trans Supreme® is also suitable for use in the following automatic transmission applications: ... Honda ATF DW-1; ATF Z-1 P/N 0822-9001“. http://www.schaefferoil.com/documents/90-204SAT-td.pdfAs with all things, do your own due diligence.
[Re: wdn]
#4873524
09/20/18 09:03 AM
MolaKule
Global Moderator
Global Moderator
Posts: 20,623 |
The manufacturer’s statement: “All Trans Supreme® is also suitable for use in the following automatic transmission applications: ... Honda ATF DW-1; ATF Z-1 P/N 0822-9001“. http://www.schaefferoil.com/documents/90-204SAT-td.pdfAs with all things, do your own due diligence. The link you provided is speaking SPECIFICALLY to Schaeffer's #204SAT ATF, a MUlti-vehicle ATF. The OP is referring SPECIFICALLY to Schaeffer's #239S, a fluid for HD equipment: http://www.schaefferoil.com/documents/125-239S-td.pdf and available in SAE Grades 10, 30, 50, and 60. "CAUTION: This oil is specially formulated for use in power-shift transmissions. Do not use in diesel engines. Shortened engine life could result due to heavy piston deposits....Super Lube Supreme is not recommended for farm tractor equipment that employs a common reservoir for transmission and hydraulic systems or those Allison Transmission on-highway applications that specify the use of a fluid that meets TES-295 or TES 389 specifications. "
[Re: salesrep]
#4882790
09/29/18 06:29 AM
alarmguy
Posts: 3,435 |
Ok, call me stupid but Im lost here.
What the heck kind of fluid is it? In the OP nowhere does it say automatic transmission fluid so why are we discussing auto transmissions? I guess because manual transmissions are rare now?
Anyway, here is my question, IS THIS transmission fluid formulated for manual transmissions or not? When I saw the 15/40 I assumed we are talking manual transmission and the only reason it caught my attention but the posts are about automatic.
It caught my attention for my 2014 Harley Road King, even though, yes, a 20/50 would be better. Mobile and some others make a manual heavy duty oil but are sold in 5 to 50 gallon drums making it impossible to buy in small quantities, I guess, again, not much demand.
Oh, now I get it, down the thread someone posted a link to another product which is auto transmission fluid and nothing to do with the OP. Thanks for the info on the straight weights too, might be something more for me ... GL1
Only thing is, not so sure any of these products are readily available to the public.
UPDATE: Just as I suspected, not produced for the small consumer, only sold in large buckets for $250.00 each.
(it makes Harley Davidson Trans Mission Fluid seem dirt cheap "Formula+" @ less then $10.00 a quart.
14 Road King (current) 08 VStar 1300 Tourer 07 Suzuki C50
[Re: salesrep]
#4885744
10/02/18 05:18 PM
userfriendly
Posts: 2,946 |
[Re: salesrep]
#4888703
10/05/18 08:55 PM
parmm
Posts: 17 |
Was asking specifically about the "All Trans Supreme" suitable for use in the following automatic transmission applications: ... Honda ATF DW-1; ATF Z-1 P/N 0822-9001. As I said, the Honda automatic trannys are fussy! Not many ATFs out there which claim to meet Hondas DW-1. I think if Honda had their way, it would only be Honda fluids. Sorry I got it in the wrong place
[Re: salesrep]
#4888809
10/05/18 11:00 PM
salesrep
OP
OP
Posts: 3,618 |
"All Trans Supreme® is not recommended for use in those passenger cars and light duty trucks that specify the use of Chrysler Mopar NVG 246,Ford Type F, Ford M2C33F, Ford Mercon® C, Ford Mercon® LV, Automatic Transmission Fluid Type G, GM Dexron® VI, Honda CVT, Honda Genuine, JWS 3324 (WS), Nissan CVT type fluids, or in dual clutch transmissions (DCT) or continuously variable transmissions (CVT)." Schaeffers TD sheets lay it out. If it is listed.....it works, if they say no. then dont. This is true of all of Schaeffers TD sheets.
[Re: salesrep]
#4891205
10/08/18 03:48 PM
MolaKule
Global Moderator
Global Moderator
Posts: 20,623 |
I think this is why the OP posted in:
" Heavy Equip. and Industrial Oils"
