The temps were unseasonably low last night, and mama bear turned on the Gas furnace last night because one little cub had some sniffles. No go, nothing at all.
I have spent time trying to sort it out. It worked when last used in the spring. It is entirely dead and no response at all. There is 120v to the control board inside the unit (pic below, via the lowest black wire on the left side of the board.). I thought if you jumpered the red and white wires from the controller, it would switch on? There is a error code button (middle bottom) that is supposed to flash error codes or an "ok" code via light above, but nothing happens when pushing it.
It is a York, nine years old. I last touched it two years ago replacing the inducer motor and cleaning the igniter rods. Has worked perfectly since then until it would not respond last night. I can't find good diagnostic references online.
How can I test the thermostat vs board to ID which is bad? The thermostat is a commn Honeywell, th4110d1007.
