I spun a bearing in this 3.8, was going to throw a short block in it but the light knock and lack of particles in the oil I drained out have me hoping I can wet sand the journal and throw a new bearing on whichever rod is knocking.
I got everything I out (due to my large hands I had to pull the passenger cv axle and oil filter housing to get to the bracket) which hid the last oil pan bolt.
Turns out someone else had been into the oil pan as it has no windage tray/gasket and has straight rtv on it.
However that sucker is on nice and tight. I tried a prybar but was afraid of chipping the cast aluminum and a 2x4 and mini sledge didn't work either. Not sure what more I can do without pulling the engine at this point.
