Originally Posted by clinebarger
Originally Posted by OVERKILL
Originally Posted by ram_man
No doesn't change.
So now, MAF plugged in or unplugged it just runs like a bag of poo?
With the IAT sensor being part of the MAF sensor, Unplugging it doesn't work like it used to....Unpinning the MAF signal wire from the connector & seeing if fuel trims correct is a much better approach. That is IF this will force it into speed density mode.....Nothing is like is used to be or at least you can't count on it!
Earlier in the thread, unplugging the MAF had a significant effect on how it ran; dramatic improvement. Hence my further query regarding this behaviour, which appears to have changed. I believe observed fuel trims were also noted and discussed at that time.
