2010 Chevy Traverse with 140, 000 KMs owned since new.
About 20,000 Kms ago, the vehicle had some clunking noise from the front and I replaced the worn sway bar end links. Noise disappeared.
Recently, about 2500 KMs ago, it started to have clunking noise again from the left front. Checked the end links and they were nice and tight. Suspected the sway bar bushings and replaced them yesterday. The noise is still there after the replacement.
During the repair, I noticed that the inner side of the front tires has more wear than the rest.
The noise can be heard when at low speed over some small bumps. On smooth road surfaces, no noise. Neither on freeways.
Also, if I rock the car left to right, I can hear some kind of clicking/clucking noise. sounds like something's loose.
I checked the struts and didn't see any sign of oil leak. And there's no excessive bounce. Control arms looked fine, too.
I suspect the struts are the culprit. Any idea? Thx.
