belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
28 registered members (carviewsonic, Bogdon, Bailes1992, CATERHAM, AnthemBassMan, DeafBrad, 1 invisible), 1,262 guests, and 21 spiders.
Topics301,894
Posts5,204,872
Members70,798
A/C & heat don't turn on - home unit #4869469 09/15/18 02:39 PM
R
RamFan Offline OP
R
It's been mild here for the past two weeks so we've not had the A/C on. Today is a bit of a warm day so I wanted to turn the A/C on and noticed that the A/C didn't kick in when it should've based on the way it's programmed. Turned the program off and switched it to A/C mode and set the temp to 75*, no dice. Turned the fan on, and that works just fine. Decided to see if I set it to heat if it would kick the heater on, no dice again. Mind you, when I manually switched to heat or cool, neither a snowflake nor flame appeared on the screen.
Sounds like my thermostat is the problem, thoughts?
18 Giulia Ti Sport Q4
  • 2.0T I4 - 24k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 68k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869472 09/15/18 02:45 PM
dbias Offline
Check the fuse on the circuit board of the hvac unit.
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: A/C & heat don't turn on - home unit [Re: dbias] #4869486 09/15/18 03:01 PM
R
RamFan Offline OP
R
Fuse looks good and nothing tripped on the breaker. According to my wife, she had it on yesterday for a few hours.
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869499 09/15/18 03:25 PM
P
Padawan Offline
P
Sounds like a faulty thermostat to me.
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869503 09/15/18 03:27 PM
P
Papa Bear Offline
P
Thermostat battery ??
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: A/C & heat don't turn on - home unit [Re: Papa Bear] #4869533 09/15/18 03:56 PM
P
Padawan Offline
P
Good point -- definitely check the batteries before replacing the thermostat. In my case when we had a similar issue, unfortunately the batteries didn't make a difference and I had to replace the entire unit.
Re: A/C & heat don't turn on - home unit [Re: Padawan] #4869538 09/15/18 04:02 PM
CT8 Offline
What does a faulty thermostat sound like?
2015 F150 2.7
2018 F350 6.2
Re: A/C & heat don't turn on - home unit [Re: CT8] #4869556 09/15/18 04:19 PM
T
Triple_Se7en Offline
T
Bang on it twice with your fist. Then you will instantly become familiar with the sound.
Trolled Here? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
Re: A/C & heat don't turn on - home unit [Re: Papa Bear] #4869572 09/15/18 04:29 PM
G
Garak Offline
G
I'd definitely check that. Mine exhibited some strange behaviour when the batteries ran down, and there wasn't a low battery warning, either. Things just started to "not work" very well, with AC not kicking on when it should have.
Plain, simple Garak.
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869588 09/15/18 05:03 PM
R
RamFan Offline OP
R
I pulled the thermostat and wired the hot to the a/c, heat and fan and all worked accordingly. Thermostat confirmed.
Could've been the batteries, but it's a 12 year old unit and has had quirks over the past two years anyway so I'm just replacing it.
Thanks for the feedback!
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869648 09/15/18 06:25 PM
J
jhellwig Offline
J
You can see the low battery indicator on in your picture. I have that exact same thermostat and they are quirky. This time of year they like to kick into a delay mode where it waits before turning on. The flame or snowflake will flash for a few minutes before any thing happens.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869697 09/15/18 07:39 PM
1
14Accent Offline
1
Get a smart 'stat! Now's the time to upgrade...
I love my Ecobee. Just saying.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869739 09/15/18 09:07 PM
CT8 Offline
LOL
2015 F150 2.7
2018 F350 6.2
Re: A/C & heat don't turn on - home unit [Re: RamFan] #4869825 09/15/18 11:32 PM
O
oldhp Offline
O
I have one exactly like this and it stopped too. New batteries fixed it, at least on mine.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: A/C & heat don't turn on - home unit [Re: jhellwig] #4869832 09/15/18 11:40 PM
R
RamFan Offline OP
R
Oh yeah, I've played that flashing indicator game plenty of times. Its the strangest thing but this unit loves eating batteries, or at least acting like it's eating them. I've gone through 4 sets of batteries in 2 years. Fresh ones are good for about a month, then the battery indicator will come on and the unit will die 5 to 6 months later.
