Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
85 registered members (4WD, 55hambone, 555, 1978elcamino, 2015_PSD, 64bawagon, 8 invisible), 2,143 guests, and 80 spiders.
Topics306,053
Posts5,286,496
Members71,593
Page 1 of 3 1 2 3
Low Viscosity Effect on Heavy Duty Engine Components #4869092 09/14/18 11:51 PM
Shannow Offline OP
https://www.researchgate.net/public...t_on_heavy_duty_diesel_engine_components
Not a bad paper, exploring the wear behaviour between
15W-40 and 0W-40 HDMOs
15W40 and 10W-30 low HTHS oils, and some material changes to work around the increases in wear.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4869224 09/15/18 08:44 AM
J
JLTD Offline
J
Sounds fascinating, marked for later reading.
Lates.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4869250 09/15/18 09:26 AM
T
tig1 Offline
T
yep, gotta use the right oil.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4869341 09/15/18 12:37 PM
B
BrocLuno Offline
B
Thanks, very interesting, but dropping from XW-40 to 10W-30 is not terribly radical. Good 10W-30's may be approaching SAE 30 HD straight grades for performance ...
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4869346 09/15/18 12:43 PM
B
benjy Offline
B
from reading it seems that the ONLY way thinner oils work is with newer coatings + metallurgy + although 500 hrs is a good test the "real world" coulh have different results! like drug manufactures that test their own drugs that always work i am skeptical of what oil manufacturers are "trying" to make us believe!!
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4869428 09/15/18 02:28 PM
Cujet Online Content
Online Content
Exactly, a 0W oil increases liner wear by 100%, but, but, but, we have newly developed components that will live a long time with that thin oil.
Of course they do. We've had very long life components for decades now. Good luck getting manufacturers to employ such expensive technology.
One interesting example includes Nikasil cylinder liners plated on to steel. It's a very robust combo (as long as there is no sulfur in the fuel) , and with the use of moly faced rings and moly coated or anodized piston skirts and other DLC coated parts, will outlast a "conventional" cast iron bore with chrome rings, about 2 to 1.
For double or triple the cost.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: BrocLuno] #4869537 09/15/18 05:01 PM
G
Garak Offline
G
They were using a 10w-30 with an HTHS of 2.9, though, not a traditional HDEO 10w-30 of 3.5. I was confused until I saw that.
Plain, simple Garak.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4876380 09/23/18 01:35 AM
K
Kamele0N Offline
K
I am waiting for StevieC to chime in smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Kamele0N] #4878741 09/25/18 12:37 PM
StevieC Offline
This isn't a smoking gun either because it's not all engines under all applications tested with every oil formulation possible. I think that if the engineer that designed the engine properly with the use of a thinner viscosity in mind for normal operating conditions then it should serve the user quite well to far past expectations as I said previously. Are there going to be occasions where a thicker would perform better? Sure. Should we run a thicker oil all the time out of fear because we think we know better? Nope. That is what I was arguing in the other threads.
The answer at the end of the day is there is too many variables and we have missing information from the engineers that made said engine and said oil in use and what their take would be and reading world wide owners manuals is not the smoking gun folks think it is.
cheers
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: StevieC] #4879438 09/25/18 11:02 PM
Shannow Offline OP
Yeah, you stated in the other thread(s) that as the studies aren't all engines and all circumstances, that they were equivalent to wild suppositions based on imagined engines, and imagined operational circumstances.
I disagree.
If it's the truth....it can handle the pressure !!!
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4879578 09/26/18 07:01 AM
J
JAG Offline
J
It’s like not accepting Newton’s laws of motion because testing hasn’t been done on every mass and every net force.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: JAG] #4879596 09/26/18 07:26 AM
Shannow Offline OP
And the completely ridiculous to the posted topic "not the smoking gun" "all engines all circumstances" "world wide owners manuals" "too many variables"
Is akin the "protesteth too much" from Hamlet....
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4879618 09/26/18 08:03 AM
J
JAG Offline
J
Haha. The thoughts are more twisted than Gumby. I know not to argue with people on subjects in which they know more than I do.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: Shannow] #4879670 09/26/18 09:29 AM
StevieC Offline
I disagree.
As I said in the other thread. Does it warrant more investigation sure, is it a smoking gun for all situation absolutely not.
Re: Low Viscosity Effect on Heavy Duty Engine Components [Re: StevieC] #4880065 09/26/18 04:07 PM
Shannow Offline OP
Smoking gun for what ?
The paper is about..."the effects of Viscosity on Heavy Duty Engine Components"...it IS the investigation on the stated topic, not the subject of investigation.
By qualified people, not zealots whose understanding of science, engineering, and the scientific method asymptotically approaches zero.
Page 1 of 3 1 2 3
