second Betta won’t eat bloodworms
by BossMoss. 04/19/19 01:03 AM
Battery Chainsaw - new purchase
by Shannow. 04/19/19 12:32 AM
PQIA six new 5w20 samples tested (name brands)
by SlavaB. 04/18/19 11:49 PM
MotoTech oil sale @ Fred Meyer
by SlavaB. 04/18/19 11:40 PM
being a luthier/
by koffy. 04/18/19 10:31 PM
2019 GMC Syclone
by oilpsi2high. 04/18/19 10:11 PM
KYB Struts from Rock Auto
by Snagglefoot. 04/18/19 10:10 PM
Thump/slap after rear pinion seal replacement
by HoosierJeeper. 04/18/19 09:55 PM
Dealer bulk oil
by leeaspell. 04/18/19 08:44 PM
Help me identify this tie rod washer
by Klutch9. 04/18/19 08:40 PM
Sears suing Lampert for looting them
by slacktide_bitog. 04/18/19 07:45 PM
Champion COS10575 bypass pressure
by Snagglefoot. 04/18/19 07:39 PM
New oil filter cutter
by kstanf150. 04/18/19 07:26 PM
Cat 435-5142 // 2016 LML duramax
by Shata. 04/18/19 06:52 PM
Free to all: Assassin's Creed Unity (PC)
by Rand. 04/18/19 06:29 PM
AC DELCO "PROFESSIONAL" PF 64 CUT OPEN
by 53' Stude. 04/18/19 05:47 PM
Offset
by jcartwright99. 04/18/19 04:07 PM
Honda Camera Design...FAIL
by Sayjac. 04/18/19 04:02 PM
rotella t4 vs delo
by 1978elcamino. 04/18/19 03:50 PM
fatafox, CurtC, LockCracker, fawkes, Kenzitoz
67848 Registered Users
53 registered members (billt460, Astro14, 4WD, 87sammy, A1O, 2015_PSD, 6 invisible), 688 guests, and 26 spiders.
Topics287,727
Posts4,933,171
Members67,848
Most Online2,967
Mar 10th, 2019
LS Differential fluid in a Torsen Differrential? #4868270
09/14/18 02:57 AM
09/14/18 02:57 AM
Munich, Germany
ChristianReske Offline OP
Munich, Germany
I am puzzled.
My car has a Torsen differential. This has some "Clutch Discs" ("Washers") and relies partly on friction for proper function. See attached pages from the Workshoip manual.
The owner manual only says "Use SAE 90 GL 5 Oil", no mention of LS Fluid.
Is it safe to use LS diff fluid in this type of differential or could this cause problems (To much fricton, harming the waschers, shearing the holding tabs of....) ?
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4868273
09/14/18 03:09 AM
09/14/18 03:09 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Its doesnt use any clutch frictions. All the friction is in the planetaries against the case of the unit.. What I have heard is that LS additive may reduce the bias ratio of the unit, which is a measure of how well it works. LS additive, which is Friction Modifier does not increase friction, it reduces it. so the gears slip easier.
I would try to find a gear oil that does not contain LS additive for maximum performance of the unit, but I do not believe it will cause any long term harm or damage if it is used; just a loss of its capabilty for as long as the LS additive remains in the case.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4868281
09/14/18 03:43 AM
09/14/18 03:43 AM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
https://torsen.com/lubricant-part-1/
https://torsen.com/lubricant-part-2/
"In truth, a Torsen differential typically isn’t that fussy about which lubricant you choose – within reason. A Type-2 or T-2R model will operate in really any common lubricant, ranging from ATF to heavy weight gear oil. On the other hand, if you happen to be using a Type-1 differential, you need to a little more choosy. The crossed-axis gear mesh of Invex™ gearing requires the use of oil with high-pressure additives. This means they need gear oil with a GL-5 rating. But even that isn’t too difficult. Hypoid ring & pinion gears have the same need, so almost all normal axle lubricants are up to the challenge. But be sure to look for the rating on the bottle anyway."
For a torsen, unless you're tuning for maximum performance, it doesn't really matter. As they say in the article, use the oil that makes the ring and pinion happy.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 321k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4868348
09/14/18 07:43 AM
09/14/18 07:43 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
LS additive is not needed in a Torsen diff. When I built my 4T65E I used a GMPP Torsen diff with 1" chain and it still uses ATF fed by the same diff lube tube as the original diff unit.
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4868458
09/14/18 09:44 AM
09/14/18 09:44 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Originally Posted by ChristianReske
I am puzzled.
It's safe though LS is not required.
No, it won't.
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4870204
09/16/18 02:26 PM
09/16/18 02:26 PM
Tucson
neo3 Offline
neo3  Offline
Tucson
I have a torsen diff also. It's very noisy during turns at moderate speed, say over 40 MPH. This noise is supposed to be common, usually called a "rocks in a box" noise. I've read that using the LS additive may quiet it down, even though it's not supposed to be needed in a Torsen. I currently have Supertech 85W140 in it (which has no LS additive), which I thought would quiet it down (it's supposed to take 75W90), but if anything made the noise slightly worse.
Re: LS Differential fluid in a Torsen Differrential? [Re: neo3] #4871391
09/17/18 07:33 PM
09/17/18 07:33 PM
ohio
xtell Offline
xtell  Offline
ohio
I contacted Torsen directly asking about differential fluid for my 1999 Trans Am. I was advised to use 75w-90 synthetic fluid only. In my owners manual it is listed to use a GM friction modifier additive "if needed" to prevent creaking noise when going around corners. I have just used straight 75w-90 synthetic (Pennzoil and Valvoline) and never noticed any creaking sound from my cars differential, thus no need for a friction modifier additive.
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4874734
09/21/18 12:59 PM
09/21/18 12:59 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
posted in the wrong thread
Re: LS Differential fluid in a Torsen Differrential? [Re: ChristianReske] #4882833
09/29/18 08:36 AM
09/29/18 08:36 AM
Munich, Germany
Munich, Germany
Sorry for the late reply, just want to say thank you all!
