Usually, when you drive in a cold climate, you use low-viscosity oils to aid start up during cold weather.
But if you added a really slippery oil additive to a thicker oil, would it make start up just as easy?
Normally in a 'northern' winter, you would use a 5W or 0W oil to make start-ups easy at, say, -18C to -30C at the extreme end.
10W-30 would 'work' most would agree, but it wouldn't be ideal, and most OM's say not to use it below -18C.
Moly is generally regarded as a very good additive at reducing friction in an engine, making it run much smoother and even get better mileage, as it 'plates' on the surface and reduces friction a lot.
If you added a moly additive, like MolySlip or Liqui-moly to a 10W-30 oil and ran that through a winter, would it make the engine easy to start even if you were at temp close to where a 10W oil would have a hard time, ie -25C? Would the engine crank faster bc the plated moly wold reduce friction enough to compensate for the thicker oil?
