P.S.A.
The last couple years I've noticed more ALKALINE Batteries leaking.
These are AA and AAA batteries used in:
* TV Remote Controls
* Clocks
* Thermometers
* Flashlights
* Water Alarms
* Smoke Detectors
* Home Security System
* Temperature / Humidity Gauges
Just this Week, I found (2) TV Remote Controls with leaking batteries.
These batteries were in use approx. 4 years.
So far I caught it in time and was able to clean and save the devise.
My solution was to switch to Lithium Batteries.
There a little more expensive but an Internet Search shows they do not leak.
They are NOT rechargeable, but I'm sure will last a long time.
Anybody have the same problem ?
What was your solution ?
If your still using Alkaline Batteries, check for leaking.
Helpful Hint: Write the Month & Year on your batteries.
I use a 'blank' Address Label and date that (easy to read).
* Clocks
* Thermometers
* Flashlights
* Water Alarms
* Smoke Detectors
