NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
129 registered members (AC1DD, 67ZL1, A310, 97prizm, 750IX, 53' Stude, 12 invisible), 2,524 guests, and 26 spiders.
Topics300,364
Posts5,174,203
Members70,491
4 hours ago
Is windshield molding just decorative? #4862433 09/07/18 01:28 PM
Blue_Goose Offline OP
Had my windshield replaced today and for the most part it looks pretty darn good. There are a couple areas on the side molding which look like they don’t seat 100% with some tiny gaps. I remember when I first went in the place to ask them about replacing my windshield I asked them how close would it look to how it does now. He was upfront and said that I had to remember that this is a replacement windshield not one installed at the factory so they will get it as close as possible.
All that being said I remember when I went to Safelite and asked the same question, the tech there told me that the molding/trim is decorative and he could put the windshield in place without any trim and it wouldn’t leak.
What say you guys? The plastic pieces at the bottom of the windshield seem a little loosey-goosed. They are not sitting hundred percent but they’re locked in. (Not sitting as tight as they were before I brought it in) I suppose that’s an easy swap if I ever wanted to do it. The only reason I’m being a little eagle eyed is the car only has a little over 2000 miles on it. I’m sure that will wear off pretty quick
2018 Honda Civic EX Hatchback 1.5T
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862451 09/07/18 01:47 PM
O
Oildudeny Offline
O
Why a new windshield at 2k.. Why not have dealer install the new windshield?
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862486 09/07/18 02:09 PM
DuckRyder Offline
The windshield is glued in with urethane. The tech is right they could leave the molding out and it wouldn’t leak.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Is windshield molding just decorative? [Re: Oildudeny] #4862495 09/07/18 02:16 PM
Pebble cracked it. I went to the dealer and they referred me to Portland glass
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862500 09/07/18 02:22 PM
Nick1994 Offline
It won’t leak without the trim or with crooked trim, but it could whistle on the freeway.
2015 Hyundai Genesis 5.0L 55k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862632 09/07/18 04:08 PM
I was actually able to fix the molding on the side where the slight gap was by believe it or not using the corner of a dollar bill lol. There was a section where it looked like it was folded under and not up against the pillar. By starting at the bottom of the window and slowly running the corner of the bill up to the fold I was able to “pop” the portion out that was folded under. It took multiple passes in maybe 15 minutes or so but now it looks almost factory. Maybe hard to visualize what I’m describing but I think it looks pretty good now
The only thing that looks like junk now is my inspection sticker, they murdered it taking it off and putting it back on. They did use an OEM window and even has the Honda logo on it
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862686 09/07/18 05:19 PM
N
NoNameJoe Offline
N
The molding is usually just decorative. They usually cover up gaps between the windshield and pillars or just panels of the body, especially where seam sealers and welds are visible.
These days they try to make car look sexier by decreasing the gaps so that they can "naturally" cover the gaps without using separate plastic/rubber molding. For example just making the windshield larger so no molding necessary on the sides.
If the fit looks "off" it might be due to clips not having seated in or something like that. The other is the windshield was installed off so now the geometry doesn't match where the trim expects it to be, but that's unlikely.
2015 Civic LX Coupe
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862706 09/07/18 05:40 PM
V
vavavroom Offline
V
Without seeing a picture I can't form an opinion on if I'd be happy with the work that was done.
Re: Is windshield molding just decorative? [Re: Blue_Goose] #4862954 09/07/18 08:44 PM
E
Ethan1 Offline
E
If you have Honda Sensing, make sure to have your windshield camera re-calibrated.
Re: Is windshield molding just decorative? [Re: Ethan1] #4863010 09/07/18 10:19 PM
Yeah no sensing. Plain Jane reg glass. To the tune of 1k including mouldings
Re: Is windshield molding just decorative? [Re: Nick1994] #4863055 09/08/18 12:34 AM
Carmudgeon Offline
I've experienced this first hand and it drove me crazy enough to have the shop redo the job.
Modern bonded windshields aren't sealed to be body via the molding, but it still has to be installed properly.
