Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
67 registered members (bbhero, Blkstanger, BlakeB, 2009Caraman, AnthemBassMan, 1 invisible), 1,539 guests, and 19 spiders.
Topics301,767
Posts5,202,370
Members70,775
Subaru head gasket failures #4861596 09/06/18 03:39 PM
E
edwardh1 Offline OP
E
I was considering buying a new one but after reading about the head/gasket problems I got to thinking, what bothers me is not that the problems occurred (seems testing might have uncovered that tho) but rather why did it take the company so long to fix it. are they real low production? and there is no money to do in process changes when dealers said hey the gaskets are leaking??
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Subaru head gasket failures [Re: edwardh1] #4861597 09/06/18 03:40 PM
dogememe Online Content
Online Content
As far as I know they haven't had that problem for years now if you buy a new one it's going to be totally fine.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Subaru head gasket failures [Re: edwardh1] #4861600 09/06/18 03:59 PM
J
JayhawkRoy Offline
J
Our family has owned three Subarus:
--1999 2.2L engine over 100K miles driven (no known head gasket issues);
--2003 2.5L engine (140K miles driven before its demise in an accident (in the middle of the head gasket problem);
--2011 2.5L 140K miles (no issues to date)
In each case we follow the manufacturer's recommendations on coolant changes and additives. The 2003 and 2011 got Subaru coolant and Subaru additive.
No issues on any engine. 2011 still running fine. I am monitoring it, because it may have lost some coolant recently.
That's our verified history of the problem.
Re: Subaru head gasket failures [Re: edwardh1] #4861606 09/06/18 04:17 PM
SnowDrifter Offline
The head gaskets on the EJ25 would typically take between 100 and 130k miles to manifest. It takes time to put that many miles on a vehicle and incur enough failures that the problem can be attributed to the design itself and not someone in the assembly line messing up. My gut feeling is they didn't really know about it for a while. Hindsight will always and forever be 2020
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Subaru head gasket failures [Re: edwardh1] #4861618 09/06/18 04:29 PM
SubieRubyRoo Offline
This hasn't been an issue for at least 10 years, if not longer. Let it die, quit perpetuating the myth. Buy a Subaru with confidence.
De omnibus dubitandum.
Re: Subaru head gasket failures [Re: edwardh1] #4861633 09/06/18 04:45 PM
ccs368 Offline
My father has an older 2006 Outback h4 and suffers from gasket failure. The head gasket failures were very common with the non turbo horizontal 4 cylinder equipped engines and believe it also effected the previous generation h4 engines. We elected not to repair this vehicle now at 110k miles and was notified at around 65k miles (3 years ago) from the dealer. It will go to the junk yard sooner than later.
This is my feeling and while only Subaru engineers know for sure it has left a pretty bad taste in my mouth and interesting converstions with a service mgr asking us if we were interested in purchasing extended plan to cover out of warranty maintenance. My feeling are the symptoms start to show as early as my father’s example but just out of the 3yr/36k warranty. The issues were not deemed road hazardous or safety issue related thus no official recall. The design of the head had a less than desirable contact footprint which created an already challenging head gasket shape which was prone to failure when the ‘coating’ started to disintegrate and leak paths formed. The combustion gas was forcing oil/antifreeze outside the head as visibly seen underneath car during inspection. The leak typically did not have a leak path towards the combustion chamber and not burning out the exhaust. The 6 cylinder and turbo 4 cylinder Subaru’s had a more robust head gasket design and had much much less reported failure rates. I believe these had a stronger MLS gasket design and not the h4 style single layer crappy gasket. My father’s car didn’t overheat or burned excessive oil/antifreeze until just recently so I believe the end is near.
Subaru had and still use an additive for the coolant to try to mitigate leaking. I think the reason why it took so long are logistics and time to failure. The gasket mfg contracted by Subaru probably made a million of these and Subaru was not willing to eat these knowing failures were starting to pop up much later and they could react to circumstances favoring corporate. I’ve also read with some customers with much higher mileage (200k) were performing head gasket repairs twice because dealers were literally performing this repair at such an alarming rate and not prepping the heads or not even sending heads out for machining prompting eventual failures again even using the newer updated approved gaskets.
If not for the fact the cylinders are horizontally opposed thus a pain to get the heads off x2 many people are finding it easier to remove entire engine and gives better access. It’s a project that I am not likely to take but the good news is if you are interested in newer Subaru’s (<3 years old)...I don’t think or read that this failure is happening as my father’s generation car. Good luck.
2015 Toyota Sienna LE FWD 0w20
2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40
2004 Harley-Davidson Fatboy FLSTF 20w50
2001 Ducati 996S 20w50
Re: Subaru head gasket failures [Re: SubieRubyRoo] #4861641 09/06/18 04:59 PM
CR94 Online Content
Online Content
Originally Posted by SubieRubyRoo
This hasn't been an issue for at least 10 years, if not longer. Let it die, quit perpetuating the myth. ...
It's not a myth. More like 7 years, assuming the current generation proves ok. One of my friends had a 2000 Forester, which manifested the typical head-gasket problem somewhere beyond 100k miles. He solved that issue by buying a new one, 2012 or so.
The old pushrod Subarus had head gasket issues too, among other serious engine flaws, circa 1973-76. Mine (listed below), being a '72, didn't. My parents' , which was a '74, had troubles only after my mother sold it to a family friend.
2011 Toyota Prius now at 109K
Re: Subaru head gasket failures [Re: edwardh1] #4861669 09/06/18 05:27 PM
B
benjy Offline
B
subaru has had issues as most do. oil burners trying to meet the EPA mpg's. they are over rated IMO + rely on their AWD to sell. i tested an impreza years ago then the jetta i bought the subie was a tin can in comparison. today the golf sportwagen with AWD is what i would buy, but only manuals on the base with awd available, but lots of other options. 200,000 miles on the 2001 jetta 1.8T when i traded it still running great, but i wanted a roadster + luckily found a 2001 TT 225 with quattro like new + am enjoying it for sure!!
Re: Subaru head gasket failures [Re: ccs368] #4861685 09/06/18 05:35 PM
M
maxdustington Offline
M
Engine removal seems pretty easy on those, there was a thread about it recently where someone posted pics. I'd totally yank the mill the replace the HGs on it at that mileage, that's not even 200k km!
99 Toyota Tercel CE 5EFE/C151
Re: Subaru head gasket failures [Re: edwardh1] #4861707 09/06/18 05:50 PM
L
LoneRanger Offline
L
A 2008 or newer model EJ25 has an updated hg design and if the owner follows the maintenance schedule and flushes coolant every 30,000 miles, puts in the genuine Subaru coolant additive, and does proper oil changes they will likely not experience a hg failure with normal operation.
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: Subaru head gasket failures [Re: maxdustington] #4861708 09/06/18 05:52 PM
W
WhyMe Online Content
Online Content
W
easier to pull the engine and put it on a stand then to wiggle all the tight spaces to do it on the car. the dohc had to come out as the head bolts are under the cams. the sohc one could be done in the car. it took me 13 hours to pull and replace the 2 hg on my 99. its my first time doing it on a sub , so there was a lot of reading the manual etc. i bet i could do it in half the time if i did it everyday. once its out do all the timing belt, valve cover gaskets all at the same time .
one thing about the older subs is that they leak oil from what seems like every orifice.
Re: Subaru head gasket failures [Re: edwardh1] #4861723 09/06/18 06:17 PM
StevieC Offline
They have fixed the Head Gasket failures as far as I know because we haven't seen repeats since the huge amount we did when it was happening. Now you just have to worry about their CVT's. LOL
Get a Stick, you're all good!
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Subaru head gasket failures [Re: JayhawkRoy] #4861746 09/06/18 06:45 PM
P
Padawan Offline
P
Our experience has been very similar to yours. We owned a 1999 and a 2001 Forester which both had over 150,000 miles when we sold them. We also currently have a 2006 Saab 9-2X (rebadged WRX) with 176,000 miles on it, and my father-in-law owns a 2005 Outback 2.5 XT with 185,000 miles. None have had any head gasket issues whatsoever.
I only ever use OEM Subaru coolant or Pentofrost A2 and always add the Subaru Cooling System Conditioner as specified in the manual.
Re: Subaru head gasket failures [Re: maxdustington] #4862061 09/07/18 06:14 AM
supton Offline
I recall that thread. Not sure it tips me over into being pro-Subaru but it makes me wonder if I should write them off as much as I have been. At some point I'm going to need yet another vehicle, and it's likely to be a cheap one. Ease of work is always a plus!
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Subaru head gasket failures [Re: CR94] #4862804 09/07/18 07:01 PM
Considering that the "official" replacement head gasket that you get from a Subaru dealer is still the same as the revised MLS gasket that came out somewhere around 2006, I'm going to stand by my statement of "at least 10 years, maybe more." The only real problem was that the original engineers did not require MLS gaskets in the first place. If the beancounters hadn't tried to save a couple bucks, there likely would have NEVER been a "Subaru head gasket issue" as we historically know it. Yes, the boxer design has its challenges. But when the proper technologies are used, it is a non-issue.
