Which grease would you use in a hi-temp, hi-speed, hi-load (short track racing ) environment? This will be used for disk brake wheel bearing. I am currently using Redline Cv2 and am not happy with how the bearings are holding up. They are repacked every 500 laps (5/8 mile dirt track). I am thinking about switching greases. I was recommended Castrol pyroplex blue by an track old timer, but also saw the pyroplex red on the Castrol website. Below are the links to product data sheets for example the blue and red.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/F7023ECA3A086ECB80257CBD003FD086/$File/BPXE-9JD3PQ.pdf
https://msdspds.castrol.com/ussds/amersdsf.nsf/Files/B7A2631A1ECC952D80258089005805B0/$File/11176454.pdf
